Can you tell me anything about a Avon Tech M550 A/S tire??
Old Jul 27, 2005 | 05:48 PM
MaximusMorpheus's Avatar
Does anybody have any info on the Avon Tech M550 A/S? Want to replace OEM's and this tire stuck out.
Found this link-- http://forums.maxima.org/showthread....7&page=2&pp=30
Just wanted more info about them.
Old Jul 27, 2005 | 10:01 PM
wheeldream76's Avatar
Nice tires. Very durable and quiet. Good reviews. I have Avon Tech M500 (summer version) for 10k + miles. Very good. However, they are VERY heavy. ~29 pds for 225/50/17. You can get tires that are 24-25 pds and it will make a positive difference.
If you don't care about tire weight - get them!!
Old Jul 28, 2005 | 05:24 AM
Thanks, so is the 550 A/S the same weight as the M500?
Old Jul 28, 2005 | 06:48 AM
d00df00d's Avatar
Old enuf to pick his own gears
29 lbs is HUGE. I would never, ever get tires that heavy, regardless of traction.
Old Jul 28, 2005 | 06:54 AM
Is 5 lbs difference between stock tire a big disadvantage?
Old Jul 28, 2005 | 10:29 AM
d00df00d's Avatar
It's a very noticeable difference, especially in the ability to track properly over rough pavement and dips in the road.
You may or may not notice the decreases in handling, braking, acceleration, fuel economy, ride quality, etc.... but unsprung weight is ALWAYS bad.
Old Jul 28, 2005 | 10:34 AM
I was looking into maybe putting 235/50R17's instead of 225/50 to get less wheel gap. Is this worth it?
Old Jul 28, 2005 | 11:06 AM
Yes, it may help some. However, if you go to 235/50...don't get the Avon tires because you'll reack 30pds per tire. !!! This is huge.
HOw does your tire weight affect your car performance....here is the math.
1 extra pound of TIRE weight will add 8 pounds to the overall weight of your car when moving. It is a very simple physics relation/formula.
So....if you get Avons that are 29 pounds, compared to 25 pouds Kumho's for example....there is a 4 pounds difference per tire. You have 4 tires. This makes 16 extra pounds of TIRE weight. Multiply this by 8 and you'll get how much extra weight your car will have to carry after you put the AVONs. This is almost like adding an additional small person. It is A LOT.
Old Jul 28, 2005 | 08:02 PM
d00df00d's Avatar
True... but that's a very rough formula and it really only works for acceleration and, to a lesser extent, braking.
What it doesn't explain are:
1. Ride quality. Adding a lot of dead weight to your car (e.g. passengers, cargo) would actually make your ride a little smoother. Adding even a little unsprung weight will make it rougher. So I guess the formula kinda still works for this, but it's more like every pound you knock off your wheels and tires has the same effect as adding 8 pounds of dead weight to your car (although I think it's more like 10 or 12).
2. How the wheels track over a rough surface. If you have low unsprung weight, when your car goes over a bump or a dip in the road, your wheels will just move and follow the terrain so you keep traction. If you have a lot of unsprung weight, you'll kinda skip off the bump instead of staying in contact with the road.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
Redfox
Sep 28, 2015 10:41 AM
REDinLV
Sep 28, 2015 12:31 AM
