350Z rims have arrived
Old Aug 18, 2005 | 09:03 AM
5spdMaxSEma's Avatar
i have a 99 Maxima SE (5 speed manual) and i just got my 350z rims.
225/50/R17 is the size of two of them
235/50/R17 is the size of the other two
should i put the wider ones in the front or rear?
Sorry if this is a repeat post!!!
Old Aug 18, 2005 | 10:35 AM
BRAN808's Avatar
Wider in the back........but beware of rubbing issues if the car is lowered more than 1.5 inches in the rear. I had the same 350's on my 5th gen with Tein S-Techs and I had problems over moderate sized bumps on the road. And that was with nobody else in the car. Good Luck, though.
Old Aug 19, 2005 | 09:01 AM
dubsonmax's Avatar
If u do have rubbing issues, just roll your fender with a baseball bat. Might sound dumb but it works.
Old Aug 19, 2005 | 10:53 AM
BRAN808's Avatar
Just be careful. The metal is thick, and the paint may crack.
Old Aug 19, 2005 | 10:58 AM
big h's Avatar
Probably need to heat the area of the fender up really good before you take the bat to it.
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
