Anybody running 235/50/17s?
Old Aug 28, 2005 | 10:45 PM
S00NR1's Avatar
OU > *
I have been searching around on TireRack and found quite a few options in 235/50/17. First of all, I assume these will fit just like the 235/45/17s, but does anyone here run them?
Old Sep 13, 2005 | 06:46 PM
Stuntin' 101's Avatar
the only difference in sizes is the height of the sidewall.. 50's are a little taller
Old Sep 15, 2005 | 03:02 PM
wheeldream76's Avatar
I am running those on my rear axle, installed on 17 x 8 350Z wheels.
The tires were rubbing my fenders a little over bumps but this is because the Z wheels have different offset than stock.
I have the Michelin Pilot Sport A/S tires.
235-50-17 hides the wheel fender gap very nicely
Old Sep 16, 2005 | 06:25 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i use to run micheline pilot a/s in 235/50/17. no rubbing but only dropped on maxspeeds. the tire filled the remaining gap well and i loved the tire but not the cost.
Old Sep 19, 2005 | 03:29 PM
Vad3K's Avatar
225/50/17 front, 235/50/17 rear (350z), didnt see any rubbing at all, but the wheels feel a bit heavy. id go with 45 if i would get new 17's
Old Sep 23, 2005 | 12:05 PM
X_ReDEyE_X's Avatar
Would it make a big difference going one size wider than the stock 225/50/17's to 235/45/17's?
Old Sep 23, 2005 | 12:23 PM
icelandmaxima's Avatar
Maxima Fanatic
I'm about to buy some tires and im gonna go with 235/45/17 and 225/45/17. 50 profile is too much for 17's at least when "I" compare them to my stock 16's.
Old Sep 27, 2005 | 10:46 AM
Blu's Avatar
Blu
the tits
235/50/17 look terrible IMO, looks like monster truck tires on stock wheels.
Old Sep 27, 2005 | 11:24 AM
S00NR1's Avatar
OU > *
Ya, I ended up going with the 235/45/17s anyway.
Old Sep 27, 2005 | 12:06 PM
aLtWeEzY's Avatar
guess it all depends on your stock offset. 235/50 for me
Old Sep 28, 2005 | 09:05 AM
Maxima Fanatic
the offset wouldnt really contribute to the overall diameter just the width and height of the tires sidewall
captchaos
Mar 15, 2016 12:18 PM
junito1
Sep 23, 2015 12:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
