Newbie Q on aftermarket wheels install - please reply
Old Oct 3, 2005 | 12:46 PM
Vad3K's Avatar
i got a set of aftermarket 18s and they do not sit on the rotors in the center like OEM wheels would. what is that part called that you put in between the rotor and the wheel so that the wheel sits firmly and isn't being held by just the lugs?? its not the wheel spacers, it is? thanks.
Old Oct 3, 2005 | 02:47 PM
Ammi's Avatar
350 Detroit Muscle
hubcentric rings you mean?
Old Oct 3, 2005 | 04:20 PM
Vad3K's Avatar
probably yes, never dealt with them basicly its the part that lets the center hole of the rim sit tightly on the hub (otherwise it is held only by the bolts if i would install them like that)
Old Oct 3, 2005 | 08:08 PM
Ammi's Avatar
350 Detroit Muscle
yes that would be hubcentric rings. I recommend you get a set of those
max_speed97
Aug 26, 2015 07:46 PM
Economic_Rage
Aug 20, 2015 08:27 AM
Team STILLEN
Aug 10, 2015 04:29 PM
PhalC1
Aug 5, 2015 02:36 PM
