18" RSA Tire Pressure
Old Oct 21, 2005 | 01:44 PM
Albert's Avatar
For the OEM 18" RSA, what psi are you guys running the tires?
(Assuming you're not going according to the manual)
Old Oct 21, 2005 | 03:13 PM
ramberg's Avatar
GrandPa
Check out this site and ask the question.
http://forums.maxima.org/showthread....ight=rsa+tires
Old Oct 21, 2005 | 05:11 PM
Jeffs04SE's Avatar
i always ran 35 up front and 32 out back. ran this pressure on both my maxima and my grand am
Old Oct 21, 2005 | 06:47 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Open the glove box and look at the attached sticker, you need to follow the manufacters recommend tire PSI because they take into consideration the vehicles weight and handling characteristics.
Old Oct 21, 2005 | 06:50 PM
ramberg's Avatar
GrandPa
If it not there, its under the top cover of the arm rest.
Old Oct 21, 2005 | 07:36 PM
chernmax's Avatar
Damn dude, thanks for catching that, that's actually what I meant, under the arm rest... Silly me
Old Oct 21, 2005 | 08:00 PM
SilverMax_04's Avatar
Based on an earlier thread on this subject, I am running 35 psi both front and back. It is a little higher than Nissan recommends, but should give me slightly better mileage with (IMO) little difference in handling.
I no longer have RSAs but Michelin Pilot Sports. I'm hoping the slightly higher pressure will also give me better wear on these tires than I would get at the lower pressures.
Finally, the correct pressure for an RSA will probably not be the same as for a Pilot Sport.
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
