Help - Tire choice
Old Nov 11, 2005 | 07:12 AM
03maxima1's Avatar
Help - Tire choice
I had 225/40/18 tires and the car drove like crap in comparison with the stock wheels which are back on the car 225/50/17. Yes, the tires were balanced but I never got an alignment. I believe it had something to do with the tire size. Luckily the tires had a defect and I’m getting new tires. However, I can’t decide between 245/40/18 or 235/45/18. Does anyone have a suggestion that is knowledgeable in this area as to which choice would be best for 18 by 8 wheels? I have the rims for sale in the sales thread, but I might keep them since no one has offered to buy them.
Old Nov 11, 2005 | 08:15 PM
katana's Avatar
You need to try to stay close to the OEM size for best results IMHO
check this site to find the right size
http://www.miata.net/garage/tirecalc.htm
Old Nov 15, 2005 | 03:49 PM
Peabo5000's Avatar
I have 225/40 18, which are the recommended size. But I like the OEM 235/45 17 better as well. But I think 45 series in 18 will slightly affect the speedo readings.
Which is why I'm going to go with the G35 17's on 235/45 17..... I should have dropped first though. I hate the gap.
Old Nov 17, 2005 | 02:46 PM
03maxima1's Avatar
To my knowledge OEM is 225/50/17. And the smaller the diameter difference the better, which would mean that 245/40/18 is best.
Old Nov 19, 2005 | 10:19 AM
grateful1's Avatar
Stock on my 2002 GLE is 215/55/17 and I believe it is the same on the SE as well. There aren't too many tires made in this size so many of us are running 225/50/17 as it is a comparable size to stock.
Old Nov 21, 2005 | 08:20 AM
NisMoN00B's Avatar
+Cru OG
standard size on the 2002 SE is 225/50/17. Mine came this way.
As for the 18" tire question, the best tire to run is a 235/40 if your wheel is 8" wide. with 8.5" wide wheels, you can run a 245/40 or a 235/40.
Old Nov 21, 2005 | 08:23 AM
wimpwgn's Avatar
What brand of tires do you have?
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
