19x7.5 +45mm offset 245/35 on a 5.5 gen..will i have any problems?
Old Nov 15, 2005 | 07:08 PM
wope's Avatar
I'm not lowered and not sure if I will ever, but I'd like to know if this setup will have any problems? I'm mainly concerned with the offset as most threads I have read mention 30-35 and it is also only 7.5" wide.. Will it sit in the fender well and all?
Thanks a lot
Old Nov 20, 2005 | 08:29 PM
wope's Avatar
bump bump bump
Old Dec 7, 2005 | 10:03 PM
Triple8Sol's Avatar
I miss the .org!
Yes. Problem is that they're too narrow for a Max and they'll look super tucked with that offset and width.
As for that size tire, that's a bit wide for that wheel. It'll probably still work, just not well. You'll sidewall will be rolling over on u...
Old Dec 10, 2005 | 07:06 PM
twinturbozs's Avatar
245 is too wide for a 7.5" rim, you would need a minimum of 8" preferably an 8.5" though.
Old Dec 11, 2005 | 07:15 AM
Ammi's Avatar
350 Detroit Muscle
You'll need 235/35/19s. You can use them but they will not look flush w/ the fender at all especially the rears. You can use spacers to push them out if you like. If you are getting 19s, you should have gotten at least 8" wide wheels.
MAXSE5SPD
Sep 17, 2022 04:00 AM
RinconI30
Jun 11, 2016 08:25 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
steveyphat
Sep 15, 2015 03:43 PM
