can u please help
Old Nov 20, 2005 | 02:12 PM
shaunkey1's Avatar
can u please help
i am very interested in buying rims and the ASA AR1 had cought my eye the rims can be found on tire rack i was wondering if i get the 18X 8 rims would they fit on my 5th gen max i would also like your opinions in the rims and any feedback about the company. also with 18s how much room do i need to drop my car. another question i have is what tire should i purchase.. and in advance thanks for your help
Old Nov 20, 2005 | 07:36 PM
irish44j's Avatar
retired moderator
yes, they will fit. Make sure to get them with an offset between 45 and 30mm.
you should put 235/40/18 tires on them to keep the overall diameter same as stock.
tires: I suggest Toyo Proxes 4 in the above-mentioned size.
btw, for others, here's a pic of the wheel:
Old Nov 20, 2005 | 07:54 PM
shaunkey1's Avatar
what is the 45 to 30 mm offset mean sorry about the question just trying to get knowledge before i purchase
Old Nov 21, 2005 | 06:25 PM
irish44j's Avatar
retired moderator
offset is how far it sticks out from the hub....45 offset will put it about where the stock wheels are. 30 offset will push it out flush with the fenders (like mine) - check out my webpage for pics if you want to of 18x8 with 30 offset.
don't go more than 45 or less than 30.
Old Nov 21, 2005 | 07:36 PM
Cutler's Avatar
245/40/18 with 35mm offset is what I would pimp.....
