Altima SE-R?
Old Jan 4, 2006 | 10:04 AM
motorheadwannab's Avatar
Altima SE-R?
I love the Altima SE-R rims and want'm on my max but the bolt pattern is way diff. What are my possibilities?? Has anyone ever tried this, ya I kno they are probably really heavy but hey i like how they look especially compared to my hub caps
Old Jan 4, 2006 | 12:42 PM
NmexMAX's Avatar
dot dot dot ...
Who told you that lie?
Not sure on exact weight, but they are forged.
Old Jan 4, 2006 | 01:14 PM
Deckdout2's Avatar
Play with my balls
Pattern should be the same......
Old Jan 4, 2006 | 01:19 PM
Jeff92se's Avatar
I'm needing a caw
Unless the Altima uses some oddball offsets, they should be a direct fit. I'm guessing the offsets are fine. The bolt pattern is of course fine and maxima compatible.
Old Jan 4, 2006 | 02:33 PM
CCS2k1Max's Avatar
SE-R wheels are 18x8JJ, 45 mm offset. The real question is, why not got aftermarket. Might as well go for a light weight wheel at this price
Old Jan 5, 2006 | 06:29 AM
NmexMAX's Avatar
dot dot dot ...
They are also 5x114.3 ...
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Dec 12, 2015 09:39 AM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
