Will a 34MM offset fit?
Old Jan 9, 2006 | 05:43 PM
idnumber1's Avatar
Hi,
I am going to get some new 20 inch shoes on my Max tommorow. The flipside is that the shop informed me that they only come in a 34 MM offset, which sounds kind of weird since i normally see 35 mm, 40 mm etc. Anyway, do you think I would be OK with a 34 MM? Or is it pushing it?
These are the wheels
http://www.mhtwheels.com/wheel.cfm?brand=2&cat=96
Thanks!
Old Jan 9, 2006 | 05:47 PM
pkane3's Avatar
Originally Posted by idnumber1
Hi,
Thanks!
I'm not sure, but those wheelz are bad azz!!
Old Jan 9, 2006 | 06:31 PM
boone's Avatar
You gon' pay what you owe
They may fit. The problem is going to be the bracket holding the front calipers. I would have them to test-fit one on the front before they mount the tires.
Old Jan 9, 2006 | 06:33 PM
idnumber1's Avatar
Thanks for the reply boone. What offset are you using on your wheels?
Old Jan 9, 2006 | 06:38 PM
boone's Avatar
They have an offset of 42. The design of the back of the wheel is going to make all the difference.
Old Jan 9, 2006 | 07:08 PM
Killah Kane's Avatar
Definately a nice set of wheels you are getting!! Excellent
Old Jan 9, 2006 | 07:51 PM
desmo_dude's Avatar
Hi,
Thanks!
I am really curious if those rims will fit your car. I love the look of them, and was looking at those exact rims for my Magnum before I finally settled on TSW Zandvoorts, but was skeptical those spokes of the N5's would clear its ginormous front calipers. Then I thought, maybe I'll try them on the wife's Maxima instead.... But the Maxima's calipers are almost as big as the Magnum's, so I'm pretty skeptical.... Assuming it clears the calipers, that offset will push your rim edge about 20mm further out than stock, which IMO is about perfect, but increasing the chance of rubbing the front tire with the wheel turned, going up curbs, etc. Let us know how that works out too.
Old Jan 9, 2006 | 08:06 PM
irish44j's Avatar
retired moderator
I run 18x8 with a 30mm offset in the summer (in a 5th gen). They fit no problem, with no rubbing on 235/40/18 rubber. 6th gens have more room in the wheel wells than the 5th gens. you should have no problem, as long as you keep the overall diameter stock (i.e. GET THE RIGHT SIZE TIRES!)
btw, I have 6th gen rotors and calipers on my car, and they clear easily.
Old Jan 9, 2006 | 09:05 PM
desmo_dude's Avatar
The spokes on your wheels stay at the edge of the wheel, so there's no danger of them interfering with the caliper. The N5's spokes that he's getting curve inward to form that nice big lip, so the possibility of hitting the caliper is VERY real. You can't just automatically assume that it will fit just because it's a 20". Stock wheels on my Magnum are 18". I couldn't fit Foose Nitrous 20" because of this exact reason.
Old Jan 10, 2006 | 12:57 PM
irish44j's Avatar
retired moderator
I'm not automatically assuming anything, I'm simply stating that my 18s fit. (my G35 17's and 5Zigen 17's also clear my 6th gen brakes)....
all I can talk about is what I know. All you can talk about is what you know. If he wants to buy wheels that are 3+" thicker inside around the inner rim.....that's the chance he takes.
My only question is "why?"
Old Jan 11, 2006 | 11:25 PM
idnumber1's Avatar
I decided to wait on that offset and get the tires from a dealer that said they can get them in 40mm. Ill post pics after the install
Old Jan 13, 2006 | 02:03 AM
desmo_dude's Avatar
That's gonna put you 6mm closer to the caliper.... good luck!
Old Jan 20, 2006 | 07:08 PM
idnumber1's Avatar
You are right... 40mm was cutting too close. I ended up going with the 34mm and they fit... like a glove. I will post pics soon!
Old Jan 22, 2006 | 04:08 PM
spdfreak's Avatar
Nice Weels!
spdfreak's Avatar
I meant "WHEEL"!
Old Jan 23, 2006 | 11:37 PM
idnumber1's Avatar
Hi Guys,
Sorry for the delay... here are the pics
http://www.cardomain.com/ride/2238573
Old Jan 24, 2006 | 10:15 PM
desmo_dude's Avatar
Very nice! Is your suspension stock? It looks lowered. Are you having any rubbing at all? What size tires... 255/35 ?
Old Jan 25, 2006 | 01:17 AM
idnumber1's Avatar
Thanks, I lowered the suspension with the Cattman/Progress setup, which I like very much. The tires are 245/35/20 Pirelli Assimetrico Z rated. No rubbing whatsoever, although I havent had the car full of people yet so I dont know for sure yet...
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
