Getting new rims, need help with wheel weight/bolt pattern/offset
Hi All,
Ok. So I'm looking to put 18" Enkei Evo 6 Hyper Blacks on my Black 05' Max. Why? They're not typical looking rims, they're about 160 a peice and I like the ride quality of my 245/45/18 stock tires so I don't want to change any of that.
Few questions though:
1.) Bolt Pattern, located here ~> http://www.enkei.com/Performance%20specs/evo6.html <~ I've no clue what to make of this, dose it matter what bolt pattern I get?
2.) Dose anyone know the weight of this particular rim? For the life of me I can't find the weight. I've no clue why Enkei would withhold such information!!!! I'd like to know how much weight I'm shaving off.
3.) The offset is 45 on these rims and I believe the stock offsett is 40? Will this cause any problems? If so what are the issue's and how do I address them?
4.) Is there anything I'm missing?
Here is a good sticky with plenty of info on the 6th gen
http://forums.maxima.org/showthread....01#post3768901
and here is the info you were asking about:
2004-2006 OEM:
SE
size: 18" x 7.5"
offset: 40mm
bolt pattern: 5x114.3
tires: 245/45-18 V-rated
PSI: 32 Cold
SL
size: 17" x 7"
offset: 35mm
tires: 225/55-17 H-rated
PSI: 33 Cold
2004-2006 OEM:
SE
size: 18" x 7.5"
offset: 40mm
PSI: 32 Cold
SL
size: 17" x 7"
offset: 35mm
PSI: 33 Cold
Serotta33
Sep 17, 2015 12:14 PM
0m3nc0w
Sep 11, 2015 05:21 PM
