offset question
Old Feb 5, 2006 | 02:24 PM
BRINKLEY's Avatar
offset question
there is a good deal on some 18x7.5 ALT Rival rims, but they have a 43 mm offset. Is this too much of an offset? If it is, what is a good offset?
Old Feb 5, 2006 | 02:44 PM
NoMax...yet's Avatar
Use the offset calculator in the stickys. It knows all. Easy to use also.
Old Feb 5, 2006 | 03:35 PM
BRINKLEY's Avatar
what will this tell me? and its not ez if you don't know the offset of the stock wheels.
Old Feb 5, 2006 | 03:40 PM
DrKlop's Avatar
Driving is the next best thing
stock offset is 45mm. Most people get anything in-between 45 and 30.
what kind of tires are you planning to get?
Old Feb 5, 2006 | 03:54 PM
BRINKLEY's Avatar
I'm not sure, any suggestions...... I'm on a budget too, just really like these wheels and they are at a great price in my opinion. If I buy these, it will be with my refund money.....
Old Feb 5, 2006 | 05:14 PM
Sorry, figured you would have researched that as much cr@p as people give around here for not checking stuff out yourself first.
I was able to get all my stock and aftermarket wheel info on this forum without the search option. Did take like 3 hours the first time though.
Old Feb 5, 2006 | 06:31 PM
DrKlop's Avatar
I'm not sure what's the best tire size for those wheels but, what ever size you choose don't buy tires with outer diameter larger than stock. I think 235/40-18 should be fine.
To choose the right brand, go to tirerack.com and read their reviews, also check out this thread: http://forums.maxima.org/showthread.php?t=441191
Old Feb 5, 2006 | 07:07 PM
Ammi's Avatar
350 Detroit Muscle
you'll be fine w/ that offset. I would throw some 5mm spacers though
Old Feb 7, 2006 | 12:33 PM
kcowden's Avatar
What kind of effect would the 5mm spacers have on the centering ring on the hub??
Old Feb 7, 2006 | 06:12 PM
Ammi's Avatar
350 Detroit Muscle
You mean hubcentric rings? You'll need those w/ any aftermarket rims and the spacers won't have any effect.
Old Feb 8, 2006 | 10:46 AM
kcowden's Avatar
I guess what I ment to ask is; if I have aftermarket rims and add the 5mm spacers do I also need the hub centric rings too?
Old Feb 8, 2006 | 04:10 PM
Ammi's Avatar
350 Detroit Muscle
hub ring is for your rims, not for spacers. Wether you add any spacers or not, you'll need hubcentric rings.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
