Bent Rim - Repair or replace?
Old Feb 6, 2006 | 08:22 AM
Maxima81's Avatar
Hey everyone,
Just wanted to know whether a bent rim is usually worth repairing or replacing?
To give you an idea of my situation, hit a deep pothole last night that flattened the tire (the tire ended up being slightly dislodged off the rim). It also bent a part of the lip on the inside (opposite the spokes). The affected portion is about 2-3" along the circumference and pushed in about half an inch.
Would it be practical to try and have it repaired? or should I just get a used replacement? (I have the stock 16" 5-spoke alloy rims from the 98 SE.)
Finally, if you know of any rim repair locations in NYC, please let me know.
Thank,
J
Old Feb 8, 2006 | 11:54 AM
Swazey's Avatar
same thing happened to me on my 18s, hit a pot hole goin 80, dented the inside lip of the rim. (also broke control arm and needed to get a new axle.) anyways, theres a place i took my rim to in branford, ct. he fixed it for 85 bucks. ur in nyc, so its like 2 hrs away. id say just get it fixed if you could. buying a new rim might be expensive.
Old Feb 9, 2006 | 05:30 PM
Nomad's Avatar
85 is cheap in DC area shops charge around 120.
FlaMark
25
Aug 28, 2015 10:15 AM
scarletsosa
Aug 17, 2015 09:09 PM
Samedi
Aug 12, 2015 01:54 AM
