22 x 9.5????
Old Feb 14, 2006 | 07:18 PM
MAX2DAMAX's Avatar
22 x 9.5????
will they fit my 04???, i iknow im pushing it to the limits, but the wheels that i want only come in that size, they also have 20 x 9, but what the heck if im going big might as well go huge right!
Old Feb 14, 2006 | 07:24 PM
MAX2DAMAX's Avatar
o yea this are the wheels http://www.zinikwheels.com/Z12.htm..... black of course
rkyat's Avatar
PM TEK-NIQ he's riding on 22's on his 6th gen. WITH coilovers.
Old Feb 14, 2006 | 07:26 PM
MAX2DAMAX's Avatar
the problem is if theyll hit the struts because of the width,
Old Feb 14, 2006 | 07:28 PM
NmexMAX's Avatar
dot dot dot ...
What are the basics?
bolt pattern/offset/tire size you plan to go with
Old Feb 14, 2006 | 07:30 PM
MAX2DAMAX's Avatar
Size: 22 x 9.5’’
Bolt Pattern: 5x4.5/120
Offset: +10mm
Old Feb 14, 2006 | 07:36 PM
MAX2DAMAX's Avatar
this is the wheel
Old Feb 14, 2006 | 07:37 PM
NmexMAX's Avatar
dot dot dot ...
And you forgot to answer what tire size you plan on going with.
The offset seems a bit much .... Check the wheel/tire forum for the offset calculator and see how much more it will stick out vs what's on there now. this will determine and rubbing issues you might run into.
Old Feb 14, 2006 | 07:39 PM
MAX2DAMAX's Avatar
new here, no idea where that is?
MAX2DAMAX's Avatar
found it, sorry
Old Feb 14, 2006 | 07:43 PM
D-Bo's Avatar
Droppin logs
Superbuy Tires claims:
"We can fit 22" wheels on 2005 Maxima and Altima."
http://superbuytires.com/v/Nissan/Ma...6/?diameter=22
Old Feb 14, 2006 | 07:51 PM
Hamy's Avatar
+10 offset...forget it!
Old Feb 14, 2006 | 07:52 PM
MAX2DAMAX's Avatar
still the biggest one i see is 22 x 8.5, , and im looking to fit a 22 x 9.5.... any body knows what is the offset for the factory whees (se) 18"
i know out of all the wheels out there, and i had like the ones that could give me trouble, you know some times thats the way it is, and when it hits you it hits you
KUBLKMAX's Avatar
you can fit 22's on the 6th gen max. Teq has them now with coilovers. I would also watch your gears. That is a lot of rotating mass. 22x9.5 may be an issue but I am not 100% sure of that. I hope you don't live where the roads are bad. I bet you could not fit anything bigger than a 30 series tire on that. Good luck
Old Feb 14, 2006 | 07:54 PM
KUBLKMAX's Avatar
can you not get these wheels in 20" or 22x8.5? try superbuytires.com
Old Feb 14, 2006 | 07:56 PM
MAX2DAMAX's Avatar
just found out they also have a 35 offset, does that sound more like it?
Old Feb 14, 2006 | 07:58 PM
MAX2DAMAX's Avatar
yes, i can, but i think the 22 look A LOT SWEETER, than the 20",
thankfully the roads in orange county CA, are pretty nice. so that wouldnt be an issue.
Old Feb 14, 2006 | 08:01 PM
MAX2DAMAX's Avatar
i can get them 20 by 9.5,
but i just saw a max with 22, .... WOW
Old Feb 14, 2006 | 08:03 PM
SEmy2K2go's Avatar
Go BUCKS!!!
No go. 5x114.3 is our bolt pattern.
Old Feb 14, 2006 | 08:04 PM
MAX2DAMAX's Avatar
I Know, they come in our bolt pattern, sorry about the confusion
check it out. http://www.1010tires.com/wheel.asp?w...D22%2D027C3578
Old Feb 14, 2006 | 08:07 PM
MAX2DAMAX's Avatar
talk about me, being obsesed with this wheels....
theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit uffff... theyll fit theyll fit theyll fit theyll fit theyll fit theyll fit.
Old Feb 14, 2006 | 08:19 PM
MAX2DAMAX's Avatar
any body know what the offset is for our wheels,? it doesnt tell say anything about it in the tires and wheel forum...
Old Feb 14, 2006 | 09:56 PM
NVRSATISFYD's Avatar
EXCELLENT CHOICE OF WHEELS! The wheel and tire specs are located in the sticky titled "SPECS/HOW TO" scroll all the way down to the wheel tire specs. If you have the SL 17's its 35mm and the SE 18's are 40mm.
Old Feb 15, 2006 | 02:03 AM
MAXIMA-GHOST's Avatar
You need to stay above i believe 35+ offset, but for 9.5 width i think its above 38+ offset.... and yeah out bolt pattern is 5x114.3
Old Feb 15, 2006 | 06:07 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
$528 x 4 + shipping = ~$2300
4 decent tires = ~$1400 w/ mounting
THAT'S $4000 ON WHEELS.
Old Feb 15, 2006 | 07:40 AM
MAX2DAMAX's Avatar
i can get the 22s with tires for about 2200.
Old Feb 15, 2006 | 12:59 PM
KCMAXX's Avatar
KC's FINEST
5x114.3 is 5x4.5
Old Feb 15, 2006 | 01:06 PM
MAX2DAMAX's Avatar
Originally Posted by KCmaxx
5x114.3 is 5x4.5
is good to have people that know their stuff.
Old Feb 15, 2006 | 04:50 PM
MAXDOUT04's Avatar
* THIS SPACE FOR RENT *
Are they still round?........
Old Feb 16, 2006 | 02:50 PM
MAX2DAMAX's Avatar
(Are they still round?........)
EBAY is like heaven if you know how to use it
Old Feb 21, 2006 | 04:05 PM
Tippinmax22's Avatar
22 x 9.5 will not fit the maxima Sorry ab out the bad news
Old Feb 24, 2006 | 09:04 AM
Losito's Avatar
I apologize for hijacking this thread but I have a question about wheel size and offset. I am looking to get rid of my stock wheels and move up to 20's. I believe the offset for the 20's should be +38mm but I am not 100% sure. Can someone who has 20's please let me know what offset you have on your wheels? Thanks
matty
Jul 10, 2006 12:21 AM
SoMarvelus
Jan 23, 2006 07:47 PM
jasonjm
22
Nov 18, 2004 07:15 AM
Avalon Racing
Jan 21, 2003 10:56 PM
