Would this fit the SL?
Old Feb 25, 2006 | 01:56 AM
05MAXIJJ's Avatar
Would this fit the 2005 maxima SL?
Is 8" too small compare to 8.5" ??
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Feb 25, 2006 | 03:17 AM
MAXIMA-GHOST's Avatar
i do believe these will fit.. I know some others that actually have an +40 offset..
Old Feb 25, 2006 | 09:16 AM
CanadianMoFo's Avatar
Yup. They should fit. Stick with a 245/40-R19 tyre since they are 8" wide. The OEM rims are 7.5" and the 245 is the widest reccomended for that width.
CM
Old Feb 25, 2006 | 11:23 AM
05MAXIJJ's Avatar
Thanks guys..
Old Feb 27, 2006 | 01:28 AM
05MAXIJJ's Avatar
Would 245 /35 or 45 /19 fit these rims also?
Whats the difference between 245 /40/19 and 35/45 ??
I can get tires 245/35 and 45/19 much cheaper...
What would be better 35 or 45? Or does it have to be 40? Thanks
Old Feb 27, 2006 | 04:05 AM
245/40-R19 is the proper tire size so your speedometer will be giving accurate readings. Don't cheap out and get the wrong tire size.
Try Khumo SPT. They're lower priced and have gotten some great reviews.
CM
Old Mar 2, 2006 | 08:13 PM
madmik's Avatar
If you lower the sidewall ratio from 45 to 35, you will get a stiffer ride. better cornering. Do some reading (tirerack.com) before you experiment. May lower the car a bit. I have seen member pictures with 19. Definitely a stiffer ride.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
