Question about 19'' g35 forged rims?
Old Mar 24, 2006 | 09:48 AM
2001semax's Avatar
Will the 19'' forged rays rims from the g35 coupe fit on a 2001 se max or are they too wide to fit.
wheels:
19x8front offset 30
19x8.5rear offset 33
If anyone knows, will they fit on a 01 without any issues or are modifications needed to make these rims fit?
I appreciate your input
Old Mar 24, 2006 | 09:55 AM
Jeff92se's Avatar
I'm needing a caw
Wheels = fit.
Front tires = fit
Rear tires = questionable.
I've seen them on a 4-gen and a 5-gen already.
Old Mar 24, 2006 | 10:06 AM
2001semax's Avatar
so the wheels will work i just might have to get different tires?
Do you or anyone have any recommendations on tire size?
Please advise
Old Mar 25, 2006 | 05:59 PM
irish44j's Avatar
retired moderator
there is a HUGE thread on G35 wheels on maximas....look up in the stickies here...
Old Mar 26, 2006 | 04:43 PM
2001semax's Avatar
irish i read the whole thread, but in the thread the guy who has the 19 g35 rims says they slightly rub in the rear. II just want to know what tires i can put in the rear so that there are no rubbing issues.
thanks for the input
Old Mar 26, 2006 | 06:41 PM
irish44j's Avatar
retired moderator
go with 235/35/19 or 245/30/19 and you should have no rubbing issues. They are about the same diameter as my 235/40/18 and my wheels are 18x8 with a 30 offset, which have NEVER rubbed for me, even with 5 people in the car and a trunk full of heavy stuff.
Old Mar 26, 2006 | 06:44 PM
02theMax's Avatar
Yep slight rubbing in the rear with stock springs out back. If your dropped in the rear you'll have big rubbing issues. I think it looks great with stock suspension out back though. If you want different tires run some 235/35/19's all around.
Old Mar 30, 2006 | 09:07 PM
00Maxima16's Avatar
I have an 00 maxima se...i dont want to drop it...how will 19's look on the car? will they fill out the gap in the wheel well or is it gonna look stupid because there is such little rubber? i have seen cars that have stock springs and then big wheels with very little rubber and the gap in the wheel well just makes the wheels look stupid...n e comments?
Old Apr 2, 2006 | 07:36 PM
02theMax's Avatar
That would look horrible. If you don't want to drop it then just keep your stock rims and run some new rubber 235/45/17's.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
