looking at getting some new wheels
Old Mar 26, 2006 | 11:33 PM
A33 VQ30DEK's Avatar
i'm looking at getting some SSR Professor SP1s. but i'm not sure if they will fit or not. it's 18x9 with a 31+ mm offset...
will these work or will they be to wide?
Old Mar 27, 2006 | 12:17 AM
steven88's Avatar
Need A Light?
I believe Larrio is running an 18x9 35mm offset....but hes only pushing 245 wide tires....I'm not sure how the rubbing is on his car though
31mm seems like its pushing it though
Old Mar 27, 2006 | 12:28 AM
maybe i could do the streched tire look
Old Mar 27, 2006 | 12:58 AM
steven88's Avatar
Need A Light?
235/40/18?
Old Mar 28, 2006 | 08:30 AM
Larrio's Avatar
The Definitive AE Master
It will rub at 31mm offset if:
1. you are at full lock and hit bumps
2. if you hit pot holes or dips that compress the suspension enough laterallly
The front suspension cambers when it compresses so you can play it safe by stretching a smaller tire onto the wheel. It will rub though, but eventually you see that the areas where it is rubbing is due to the stupidly designed bumps in the plastic wheel well.
Old Mar 28, 2006 | 10:59 PM
VIP Maxima
new rims again??? i think more than likely your 300zx's will not clear a +31 offset. you'll need spacers
Old Mar 28, 2006 | 11:14 PM
steven88's Avatar
Need A Light?
I thought the lower the offset, the higher the chance it will clear big brakes? Thats why people say to get spacers, when their rims dont clear the BBK...spacers = lower offset
Old Mar 28, 2006 | 11:25 PM
VIP Maxima
i thought the lower the offset the more it will sit INWARD ?
someone correct me.
Old Mar 28, 2006 | 11:27 PM
steven88's Avatar
Need A Light?
Nope...the lower the offset, the further the wheel will sit...
check out tirerack, they have a good explaination of offfsets
Old Mar 29, 2006 | 12:00 AM
skeet skeet skeet....
but yah ummm 18x9 SSR professors.... 1350 shipped from taiwan!
what if i have my camber negative?
Old Mar 29, 2006 | 12:01 AM
ummmmm wrong buddy.
the lower the offset the more clearance you get.
Old Mar 29, 2006 | 12:07 AM
steven88's Avatar
Need A Light?
I heard negative camber helps...but people say to roll your fenders before you put negative camber...do you have your fenders rolled brian?
If your okay with wearing out your tires, negative camber is the way to go...but that still doesn't guarantee that u won't rub....just a possibility
Old Mar 29, 2006 | 12:23 AM
ahhhh skeet skeet skeet
Old Mar 29, 2006 | 12:56 AM
steven88's Avatar
Need A Light?
why ahhh skeet skeet skeet? sounds like my old avatar
Old Mar 29, 2006 | 07:59 AM
Larrio's Avatar
negative camber would help at a minimal margin since it won't change the way your suspension geometry when it compresses.
You can't roll the front fender really, its mostly the plastic wheel well that rubs with the tire. And lower offset doesn't necessarily mean more BBK clearance, it depends on spoke design and hub thickness. This would be the reason why Volks are so popular since they offer the high-disk (BBK clearing) and low-disk (lip and curved spokes) version
Old Mar 29, 2006 | 09:58 AM
coool thanks larry for the info!
Old Mar 29, 2006 | 11:40 AM
VIP Maxima
ok i stand corrected. back on topic
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
