Rim down sizing?
Old Apr 9, 2006 | 12:33 PM
tcf_dk's Avatar
Rim down sizing?
How small can I go?Can I put on 16's or 15's?Couldn't find it in the stickies.Thanks
Old Apr 9, 2006 | 12:35 PM
KCMAXX's Avatar
KC's FINEST
Unless you have a 6th gen, you should check other forums. Otherwise the smallest we (6th gen) can go is 17". Anything smaller will not clear the factory rotors.
Old Apr 9, 2006 | 12:38 PM
tcf_dk's Avatar
A friend has a 6th gen and was wondering.Just to save weight and cost of tire.
Old Apr 9, 2006 | 12:41 PM
jreilly04's Avatar
make sure u get the same rolling diameter too.
Old Apr 9, 2006 | 02:19 PM
kamski's Avatar
.org extraordinaire
You would need to move down to altima brake parts and wear 225/60/16 shoes. ERGHHH or just eat a bullet and call it a day.
Kam
Old Apr 9, 2006 | 03:28 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
we have a bad wheel gap with 18's, never mind a 15" wheel on this max, damn!
Old Apr 10, 2006 | 05:31 AM
maxmale's Avatar
i hope your friend will be using them on the track. that is the only reason i would downsize...
Old Apr 10, 2006 | 05:48 AM
CanadianMoFo's Avatar
With my 17" winter rims on I can barely get my pinky in between the brake caliper and the rim. There's no way to go any smaller without changing the brakes like other posters have suggested.
Old Apr 10, 2006 | 09:40 AM
ItsTheShoes's Avatar
Smaller??? I always thought bigger was better.
Old Apr 10, 2006 | 11:40 AM
dla's Avatar
dla
Tek - - I agree with you on the wheel gap, but if someone runs a smaller rim and keeps the same diameter the net effect is the same wheel gap! They just end up showing more rubber on the sidewall.
Kam
Kam, have you seen this done on a max yet? I would not feel good about putting on smaller brake parts just to get cheaper tires. I mean 265HP/255 ft-lb and putting on smaller discs. Does that really make sense?
Old Apr 10, 2006 | 12:04 PM
MorpheusZero's Avatar
Actually, the smaller rims and meatier tires should make wheelgap less prominent.
Old Apr 10, 2006 | 02:18 PM
KCMAXX's Avatar
KC's FINEST
bottom line is on a 6th gen (which is what were dealing with) you cant go smaller than a 17 with stock brakes
Old Apr 10, 2006 | 03:08 PM
86maxima96's Avatar
I Broke OT
if the diameter stays the same, it should change the gap at all.
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
knight_yyz
Nov 1, 2015 01:34 PM
