20x8.5 tires
20x8.5 tires
I'm looking into getting 20x8.5 45 offset with 245/35/20 tires. Other offset sizes are 38 and 25.
Should I get 255/35/20?
I also ordered a 15mm spacer for the rear should I return it.
Also is that offset good. What offset would you recommend?
What load rating should I get?
I'm dropped w/ coilovers.
not too sure about your setup. i had 20 x 8.5" +35 offset on my car. it came with 245/35/20 tires. My car is also on H-Techs. The fronts rubbed like a ***** so i had to swap it out for 225's up front. Rears rubbed on dips and bumps. so i just sold the set. But thena gain this was with +35 offset, 45 offset should work for you tho.
