15 vs 16
Old May 19, 2006 | 05:44 AM
clive's Avatar
100% chingon
15 vs 16
My 96 has the 15" honeycomb wheels, 60 profile tyres. Other models have the 16" wheels.
1. Does this mean that the tyre to body gap is even greater on my model than those people with 16's or did Nissan change the ride height on the models with 15" wheels?
2. Presumably the tyre's rolling radius is smaller with the 15" wheels. So did Nissan change the gearing on these models, and for that matter, the odometer? Presumably they must have or the 15" models would have different gear ratios and the odo would be inaccurate.
If you guys don't have the answers is there anywhere I can find this out?
Old May 19, 2006 | 03:58 PM
NmexMAX's Avatar
dot dot dot ...
Aspect ratio > *
95/6
All #'s are total dia.
SE = 215/60-15 = 639mm
GLE/GXE = 205/65-15= 647.5mm
97+
SE = 215/55-16 = 642.6mm
Old May 20, 2006 | 09:15 AM
clive's Avatar
100% chingon
Originally Posted by NmexMAX
Aspect ratio > *
95/6
97+
But my 96GLE doesn't match the above, it has 205/60 - 15, not 65 profiles, and I seriously doubt the previous owner(s) would have changed the profile. WTF?
Old May 20, 2006 | 08:39 PM
96i30azn's Avatar
Theres bound to de a difference between wheel/tire size combos. i think discounttireco has a nice tire calculator. I think yours was supposed to be 205 65 15. I seriously doubt nissan or any manufacturer would change gear ratios on different trims. This is not a perfect world, tire pressures would also change the diameter, you really can't account for all that.
Old May 23, 2006 | 11:42 AM
NmexMAX's Avatar
dot dot dot ...
The case of the serious doubters.
Don't be so sure.
When they(Nissan) went to the 3.7899, I beleive it was to accomodate the 225-50-17's... Same thing in the A34(6th gen) when they changed the F/D in the 6MT again to accomodate the 245-45's-18's.
Though not official from Nissan, they did it for something, and when the math is done correctly, the RPM/MPH is the same with the new ratios vs the old.
Old Feb 21, 2007 | 01:44 PM
vansterdam's Avatar
Here's a good tire calculator to calculate tire diameters and speedometer difference.
