Fitment - 17x8, 40mm, 235/45 okay?
Old Jun 1, 2006 | 12:13 AM
Chessie724's Avatar
Eyeing up a wheel and tire set for my 4th gen on stock suspension (so far). Yes, this noob has read all the stickies and searched.
For the most part this seems to be the prime tire size for this rim and the consensus seems to be that it'll fit, no rubbing. But then I'll read some conflicting info, like a reply here and there that'll suggest I'd need spacers or that the offset is too high. So fugit, I'll just ask if this'll fit without any problems like rubbing in turns, strut clearance, etc.
Rims are 17x8, 40mm offset and a 235/45/17 tire
TIA
Old Jun 2, 2006 | 03:44 PM
BRAN808's Avatar
TIA
Should be alright. I ran 17x8's with a +38 on 235/45/17's with 0 issues. But I have a 5th gen, so I can't vouch for sure on a 4th gen.
Old Jun 2, 2006 | 08:08 PM
NISMOPower's Avatar
Perfect fitment and no rub on my car.....
Old Jun 3, 2006 | 08:31 AM
limsandy's Avatar
TIA
You'll be alright. Chop off my ***** if they didn't fit your Maxima.
Old Jun 4, 2006 | 08:47 AM
Chessie724's Avatar
Thanks, guys. I think I'll pull the trigger on 'em.
aw11power
Oct 10, 2021 04:57 AM
Matt93SE
May 24, 2019 02:58 PM
steveyphat
Sep 15, 2015 03:43 PM
JoshG
21
Sep 4, 2015 09:04 PM
mpbclutch33
Aug 21, 2015 06:09 AM
