is it ok to run 225/55W17 instead 225/50/W17
Old Sep 26, 2006 | 06:12 PM
OC guy's Avatar
2002 maxima se
I am curious to know if 225/55/17 can be put on stock 2k1 SE wheels.
Since 225/55/17" tires are little cheaper than the stock tires so i would want to give a try. has anyone tried this size on thier max if yes then do they fit right?
Old Sep 26, 2006 | 09:35 PM
WhiteMaxima9600's Avatar
They will fit no problem, your sidewall will be a little thicker than the 50 series but that's all... They will fit your rim fine
Old Sep 27, 2006 | 09:29 AM
OC guy's Avatar
2002 maxima se
^ thanks
having a thicker and wider sidewall wont make any diffrence right?
Old Sep 27, 2006 | 10:03 AM
MetaOrbit's Avatar
Got Projectors?
Your speedometer and odometer will be off.
Old Sep 27, 2006 | 10:08 AM
OC guy's Avatar
2002 maxima se
Care to explain?
Old Sep 27, 2006 | 10:36 AM
96blkonblkse's Avatar
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
225/50-17 4.4in 12.9in 25.9in 81.2in 780 0.0%
225/55-17 4.9in 13.4in 26.7in 84.0in 754 3.4%
There you go, obviously going with 225/55 compared to 225/50 your sidewall is going to be larger which means the tire will be larger seeing as your maintaing the 225mm width
Old Sep 27, 2006 | 12:28 PM
OC guy's Avatar
2002 maxima se
so you mean its safe and better to stick with 50?
i was planning to save some buck by switching to 55.
Old Sep 27, 2006 | 02:41 PM
MetaOrbit's Avatar
Got Projectors?
They're both safe. Just depends if you want to deal with your speedo/odo being slightly incorrect.
And how much cheaper are they? You can get Kumho Ecsta ASX in 225/50/17 for $88/tire last time I looked. It doesn't get much better than that.
Old Sep 27, 2006 | 05:03 PM
OC guy's Avatar
2002 maxima se
ya and 225/55/17 asx are $79 each at tire rack.
if its gonna affect my speedometer than i would not take a risk.
thanks.
captchaos
Mar 15, 2016 12:18 PM
junito1
Sep 23, 2015 12:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
