for those with staggered offset...
Old Nov 13, 2006 | 11:45 AM
JOMAN's Avatar
jus like the title says...if any of you have the staggered offset i would like to konw if any...troubles you had with this tire and wheel combo?...I am shopping for wheels... front 18x8 +38 and rear 18x9 +38 also what tired would you recommend? i have a 97 max i would like to know if think its not a good idea or not... your feed positive or constructive critism is appreciated...thnks in advance!
there are the wheels..
Old Nov 13, 2006 | 02:09 PM
timmay5835's Avatar
Those wheels are hot!
As for the offset I have no idea, sorry
Old Nov 13, 2006 | 09:00 PM
C3nthusiast's Avatar
I run 19x8.5 44mm offset w/a 235/35-19 tire and 19x9.5 45mm offset w/a245/35-19 tire.
Old Nov 13, 2006 | 09:02 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Issues? Unable to rotate.
Old Nov 14, 2006 | 12:30 AM
JOMAN's Avatar
thank you for that! do you have any tire rubber issues?...what suspension setup do you have?...
thanks in advance!
btw any pics you can share? i tried your cardomain but no pics show.
Old Nov 14, 2006 | 09:26 PM
No rubbing. Dropped on AGX and Tein S Techs. I have 1" of space on the inside and .5" on the outside before it rubs.
I'm actually going 20x8.5 and 20x10 this spring.
Old Nov 14, 2006 | 11:03 PM
The Law's Avatar
I R The Law
why would you want to run staggered for? trying to spend money on tires like crazy since you can't rotate and get the maximum life out of them
Old Nov 15, 2006 | 10:06 PM
IMO it looks better. Staggered w/ chrome 3 piece wheels. There is no substitute. Post a pic of your wheels and have everyone decide what looks better.
Staggered vs not staggered. Rotated tires vs new tires. 1 pc wheels vs 3 piece wheels.
Old Nov 16, 2006 | 05:54 PM
JOMAN's Avatar
sadly enough..those rims are friggin heavy....19's are 30 lbs...damn i'm still gonna get them ahaha....
Old Nov 20, 2006 | 10:30 AM
mad-max's Avatar
I'm using 19x8.5 (38mm o/s) with 245-40/19 on the front and 19x9.5 (45mm o/s) with 255-40/19 on the back. No problems at all.
Old Nov 20, 2006 | 04:09 PM
z32drifter's Avatar
You should be fine with those offsets. I run 17x8.5 (+40) 255/40/17 fronts and 17x9.5 (+38) 275/40/17 rears (shared with my Z32) There are no issues with the fronts, the rears rub over big dips (fender rolling would solve)
Old Nov 21, 2006 | 08:47 PM
02theMax's Avatar
I'm running G35 19's 225/40/19's up front 245/40/19's out back with minimal rubbing due to off centered beam. I love the staggered look, even if mine isn't much. As for replacing tires these are only on in the summer and I swap out my snows for winter so they don't wear out as quickly. HTH
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
ecko51
Tires and Wheels
Feb 25, 2006 12:00 AM
big h
Feb 7, 2006 12:42 PM
Mizike
Tires and Wheels
Jul 23, 2005 12:12 PM
MAX 2NR
May 25, 2005 08:19 PM
