Tire Size on 18s?
Old Dec 6, 2006 | 02:55 PM
MrDicks95SE's Avatar
Offset Is Everything.
Tire Size on 18s?
i know the best size to go with on 18x8 to be closest to stock diamter is 235/40-18 but i recieved an offer of a 225/35-18 Yoko Parada Spec set of tires pretty much new for free. what do you guys think? i kno the odo and speedo are gonna be a little off but would you do it?
Old Dec 6, 2006 | 05:00 PM
86maxima96's Avatar
I Broke OT
http://www.miata.net/garage/tirecalc.html
you be the judge. but imo, no. it is more than an inch smaller in diameter. i would have to pass on them.
Old Dec 6, 2006 | 06:23 PM
yeah i already checked the tirecalculator. if those were 40-series then id jump on them. i just need outside opinions...
Old Dec 25, 2006 | 04:03 PM
killical01's Avatar
i know the 235/40/18 would have been fine because that is what i have on my 01 max. i am now think about going up to 20" and i looking for help on thoes.
Old Dec 31, 2006 | 01:21 AM
ewuzh's Avatar
Don't do it. There won't be enough tire to fill in the fenderwell and it'll look like you have huge wheel gap, not to mention the speedo will be super wrong.
Old Dec 31, 2006 | 11:09 AM
killical01's Avatar
my gap was not that big, wish i had pic to show and for the speedo, it was off just a little nothing you would really notice. but the only thing that you would have to do is take your car to a local tire shop and have it recalb. i think it only cost me about $20
Old Dec 31, 2006 | 12:42 PM
speedymax99's Avatar
just go with a 245/40 18 that what im going to go with once my rims get here from over seas
Old Dec 31, 2006 | 01:36 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Recommended is 235/40. I'd try not to sway from that dimension.
Old Dec 31, 2006 | 10:49 PM
steven88's Avatar
Need A Light?
i would say not worth it either...possibly 235 or 245/35/18...but not 225....its just too thin and not wide enough for teh maxima
there are some good things about going 225/35/18 however....for one, your speedo will read 60 when in reality you're really going 57.7...u might be able to avoid speeding tickets :grinno....also a shorter tire will increase the final drive ratio...and boost acceleration a bit...but it will reduce your top speed
Old Jan 10, 2007 | 11:32 PM
Revs2Hard's Avatar
BARF
A 225 is way to thin for a 8 inch wide wheel it will be stretched on and look like a$$. If you are going to run a 225 then the ideal wheel would be 7 inchs wide. If I where you I would do a 245/40/18 that will be the closest to the stock size and is the best fit you can get for that width wheel. I know this because I sell weels for a huge company on the west coast.
Old Jan 21, 2007 | 08:22 PM
usa5655's Avatar
on 18s??
225/40/18 are the best because i had those before my 20"s
Old Jan 21, 2007 | 08:26 PM
SEmy2K2go's Avatar
Go BUCKS!!!
But, WHY do you think the 225/40 is a better size than 235/40?
Old Jan 21, 2007 | 08:27 PM
NmexMAX's Avatar
dot dot dot ...
225-40's are . Not enough sidewall.
Old Jan 29, 2007 | 02:54 PM
AnDyMaN's Avatar
ive had 225 45 18. it looks alright. but its a bit too thin. im getting 245 45 18 so i get a little more cushion. the s techs are too rough with 245 40 18 for me.
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
