spacer question
Old Dec 20, 2006 | 03:56 PM
MrDicks95SE's Avatar
Offset Is Everything.
spacer question
i picked up a set of 18x8 +44mm offset and i want to get spacers to make it sit flush with the body. with 10mm spacers will i need longer studs? i was told that 7mm is the bare minimum on stock studs. what are youre guys' recommendations?
Old Dec 20, 2006 | 07:08 PM
RA030726's Avatar
I'm nutty for Nissans
ALWAY use longer studs.
Old Dec 21, 2006 | 08:36 PM
hmm thats what i thought. thanks JSutter.
if i get 15mm spacers/studs in the rears will it rub? its gonna be like a 29 offset... eek.
or should i just stick with the 10mm all around?
Old Dec 22, 2006 | 08:07 AM
NmexMAX's Avatar
dot dot dot ...
With my spacers, I'm am 'running' on 25mm offset on the rears, no rubbing.
Old Dec 22, 2006 | 09:27 AM
what about the front wheels? what are you using?
Old Dec 22, 2006 | 04:24 PM
RA030726's Avatar
Stop guessing. Take 2 plumb bobs and hang one on the inside of the fender lip, then hang the other on the inner fender tub. Then place a straight edge on the hub, then you can measure your offset and backspace.
Old Dec 23, 2006 | 01:55 AM
lol ill try that.
Old Dec 23, 2006 | 02:37 PM
Ammi's Avatar
350 Detroit Muscle
I only use 5mm spacers on stock studs. Anything larger definitely need longer studs
Unclejunebug
Apr 2, 2016 05:42 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Socalstillen
Sep 26, 2015 12:01 PM
