Will 19x10 with a 15mm Offset Clear the Rears
Old Jan 6, 2007 | 12:59 AM
SpeedCrazie's Avatar
I know this sounds crazy, but just curious if this setup is possiable. Will the wheels stick out?
Thanks.
Old Jan 6, 2007 | 10:44 AM
Bump, anyone?
Old Jan 6, 2007 | 11:02 AM
whazzzzuup's Avatar
It will stick out and rub on bumps. I am running 17x9 with a +27 offset on the rear and I have to stretch the tire. I have a 235/45/17 on the rears. It is barely clearing.
Old Jan 6, 2007 | 02:02 PM
z32drifter's Avatar
On a 4th Gen? 19X10 +15 will stick out about 30mm (over 1 inch)
17x9.5 +38 (hits outer fender edge under full compression)
17x9 +34 (hits like the 9.5 +38)
I could roll the fender lip to correct the contact, but you can't roll enought for a 10 +15 you would need fender flares to cover up the tire.
Old Jan 6, 2007 | 04:42 PM
Thanks Guys!
Old Jan 30, 2007 | 10:15 PM
goldtooth's Avatar
anybody have a widebody maxima? LOLerz
Old Jan 30, 2007 | 10:46 PM
A33 VQ30DEK's Avatar
yeah talk to joe. jdouble0... whatever it is... yeah
Old Jan 31, 2007 | 02:54 AM
MorpheusZero's Avatar
Originally Posted by z32drifter
That would be SO COOL if the max were RWD...
Old Jan 31, 2007 | 06:27 PM
mikey chalupa's Avatar
Don't mean to ***** your thread, but will a 18X9 with a +24 offset fit? I found a sweet deal on a set and I don't know if they will fit.
Old Jan 31, 2007 | 08:58 PM
irish44j's Avatar
retired moderator
stick with offsets higher than 30mm if you're going with a rim wider than 8.5"......generally speaking.
matts95max
Apr 23, 2025 10:44 AM
doctorpullit
Sep 10, 2015 06:33 PM
I<3 A32's
Sep 10, 2015 11:07 AM
ef9
Sep 5, 2015 11:18 PM
