Question about rim offset
Old Jan 16, 2007 | 01:26 PM
StrangeMAX
will 18x9 28 offset wheels fit my 98 maxima flush ?
if it doesnt will it stick out a lot?
thanks a lot
Old Jan 17, 2007 | 12:56 AM
ewuzh's Avatar
thanks a lot
With the correct tire, the rear will be okay with a fender roll and possibly a slight pull. Front will stick out.
Old Jan 17, 2007 | 02:45 AM
steven88's Avatar
Need A Light?
wow 9 wide and 28mm is a pretty wide rim for a maxima
i'd say the fronts will be a problem for a 4th gen....the rears will be fine if you modify it
Old Jan 17, 2007 | 03:08 PM
StrangeMAX
http://forums.maxima.org/showthread.php?t=505994
that one looks alright tho ...what u think ?
Old Jan 17, 2007 | 03:13 PM
steven88's Avatar
Need A Light?
hes not running 9's in the front...
Old Jan 17, 2007 | 03:23 PM
ewuzh's Avatar
Like I said you need the correct size tire. If you're thinking about 18x9 +28 all around, I would suggest rolling fenders and 235 tires for the rear.
My fronts right now are 8.0" wide +31 offset w/ 235 tires and it is flush. It rubs slightly on big dips. I'm sure my problem would go away with a 225 tire. But for you to run 9.0" wide +28 offset in front...You'd need a super stretched 225 tire or maybe 215 in front to keep from rubbing lol. A little negative camber wouldn't hurt either.
Old Jan 17, 2007 | 04:30 PM
StrangeMAX
THIS SUCCCCKKKSSSS .... i'll try and see if they fit
Thanks Guys
Old Jan 21, 2007 | 06:01 PM
z32drifter's Avatar
The 9 +28 is going to stick out
these are shots of 17x9 +34 with a 255/40/17 on the front
they are going stick out 10mm+
Old Jan 24, 2007 | 01:34 PM
jac121479's Avatar
i just pmed you about this but since we're on the subject, what camber are you running with these 17x9 +34?
Old Jan 24, 2007 | 03:38 PM
z32drifter's Avatar
-1.0 degree
mikeymouse1995
Sep 18, 2015 06:42 AM
Serotta33
Sep 17, 2015 12:14 PM
steveyphat
Sep 15, 2015 03:43 PM
0m3nc0w
Sep 11, 2015 05:21 PM
adamgalazka
Sep 8, 2015 01:27 PM
