Tires for 17x8 w/ 33mm offset
Old Apr 11, 2007 | 04:24 PM
Mints33's Avatar
May be getting some Z wheels, rears, 17x8 w/ 33mm offset. Question is anyone running 235/50s? Will they rub? According to the tire cal. 235/50 is 1.5% larger than stock vs. 235/45 is 2% smaller, will either combo rub? And what's a better choice? I'm not lowered, and don't plan on it either. And how about original 225/50 tires, will they be too narrow for a 8" wheel?
Old Apr 14, 2007 | 07:52 AM
Mints33's Avatar
Anyone???
235/45 or 235/50 and why?? Thanks!
Old Apr 14, 2007 | 11:09 AM
irish44j's Avatar
retired moderator
I run 245/45/17 on 17x8 rims with 30 offset at the track...no rubbing, and I am lowered.
Old Apr 14, 2007 | 11:27 AM
Mints33's Avatar
Thanks much for the info, that's great news!
Old Apr 14, 2007 | 08:44 PM
irish44j's Avatar
retired moderator
you may have to slightly shave the inside lip in the rear wheel well, on the back side of it, where the bumper joins to the wheel arch. If you stick your hand in there you will feel that there is a big lip in that part where they join. Dremel it down a bit if it rubs. It almost never rubbed for me, but I shaved it down a little bit just to be sure.
Old Apr 15, 2007 | 09:21 AM
Mints33's Avatar
Would 225/50 work w/ an 8" rim? According to tirerack, the widest for 225/50 is 8", but how would it look? Will the tire look narrower than the wheel?
Old Apr 16, 2007 | 06:56 AM
NmexMAX's Avatar
dot dot dot ...
I hate that 'stretched' look.
8", minimally should be wrapped in @ least 235 attire.
Old Apr 16, 2007 | 03:35 PM
Mints33's Avatar
Anyone have pics of a 225/50 tire on a 17x8 wheel?? Thanks!
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
