Widths and Offsets Sticky?
Old May 3, 2007 | 10:22 PM
SpeedCrazie's Avatar
I thought this might be useful if we are able to get a good amount of combinations together.
*Since the 5th Gen Guys seem to have this already let make this for 4th Gen Only.
Post Your:
  • Wheel Brand
  • Wheel Size (Diameter & Width)
  • Offset
  • Spacers
  • Tire Brand
  • Tire Width
  • Pictures
And your thoughts on the setup (i.e. Does it sit flush or Stick out, Rubbing, etc.)
Old May 4, 2007 | 12:45 AM
Fast1one's Avatar
This is definitely a great idea, reserving a space for my setup
Old May 4, 2007 | 01:21 AM
SilverGLE's Avatar
I'm watching you, boy...
If you want to get one started for the 4th gens, you may want to post in that forum. Us 5th genners already have one going... Click Me!
Old May 4, 2007 | 04:11 PM
ewuzh's Avatar
I guess I'll start
Wheel Brand: RAYS
Wheel Size (Diameter & Width): 17x8.0/17x9.0
Offset: +31/+44
Spacers: 10mm rear
Tire Brand: Kumho SPT
Tire Width: 235/45/17 and 255/40/17
Notes: slight front rubbing on hard dips (negative camber reduced rubbing), rear fender needed to be rolled
Old May 4, 2007 | 06:45 PM
z32drifter's Avatar
Wheel brand: Enkei RPF1
Wheel size: 17x8.5/17x9.5
Offset: +40/+38
Spacers: NA
Tire brand: Sumitomo HRTZII
Tire size: 255/40/17 and 275/40/17
Wheel brand: Halibrand Cobra III
Wheel size: 17x9
Offset: +34
Spacers: NA
Tire brand: Kumho V700 (currently) / Pirelli Corsa
Tire size: 275/40/17 / 255/40/17
Notes. These are track wheels and I have been thru 2 sets of tires. the 255s are in my sig picture minor rub in the rear fender roll would correct. I have not tracked the 275s yet I know they will rub in the rear, I don't know about the fronts yet.
Here's how much the fronts stick out with the 255s
Old May 4, 2007 | 07:10 PM
abomb1987's Avatar
Wheel Brand- TSW Vortex
Wheel Size (Diameter & Width)- 18 diameter & 8 width
Offset- 40
Spacers- N/A
Tire Brand- Nexxen n3000
Tire Width 245-40-18 front & rear
Pictures.................
Old May 5, 2007 | 07:44 AM
se_nismo's Avatar
heres mine:
tenzo gt-5
front 20x8.5 48 offset/rear 20x9.5 20 offset
tires kumho front 225/35/20 rear 245/35/20
wheel spacers: none
rolled rear fenders no rubbing issues during u turns
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
