18x9 45mm offset wheel fitment question
Old May 11, 2007 | 06:15 AM
Swisscheese's Avatar
Will Mille Miglia EV-S 18 x 9 with a 45mm offset running 255/35/18 tires have a rubbing problem. These wheels are discontinued and I had trouble finding them. I don't expect any trouble out the the back wheels, however I am a little worried about the fronts. Are these going to hit my strut? is my car going to be able to turn ever again?
I would hate to have to keep looking for find 18x8s for the front, they are almost impossible to find, but id rather be safe than sorry.
Old May 11, 2007 | 08:36 AM
abomb1987's Avatar
is your car dropped, if not your ok to go, i have 18x8 and 40 offset on mine, with 245 40 18
but if your droped, you might have to roll your fenders or raise up a little bit
heres a pic
Old May 14, 2007 | 08:02 PM
A33 VQ30DEK's Avatar
you'll be good. I use to run 19x9 38mm offset in the front... dropped about 2 inches
Old Jun 13, 2007 | 02:40 PM
freddorais's Avatar
Hi , there as you can see i am a newb member and need some help, i own a stock nissan maxima 2000 GXE
I just got from a friend of mine a set of rim from an Lexus IS300 17" x 7"
The bolt pattern are the same , i found lugs nuts that can fit , my only concern is about the offset , those rims seems to be 50mm offset , will they fit , do i need spacer or any other tools , please help me out as i want to get my ugly OEM rims to trash.
thank you for your help
Old Jun 13, 2007 | 02:49 PM
ewuzh's Avatar
[...]http://img471.imageshack.us/img471/7426/frontleft1po.jpg[/...]
You won't be able to put them on the car because Lexus wheel center bore is smaller than Nissan's 66.1mm hub bore.
Old Jun 13, 2007 | 03:26 PM
freddorais's Avatar
I got them done by machine so they fit perfectly ,
My real concern are about the 50mm offset , i am a bit confuse there
Old Jun 13, 2007 | 03:56 PM
ewuzh's Avatar
Nice! Since you've got the wheels on hand, I say try them on. If it doesn't hit the suspension in front or the trailing arm in the rear then you are good to go. But with that high of offset, they will sit really tucked in the wheel wells. You'll need at least a 20 mm spacer to make them sit more flush with the fenders.
Old Jun 13, 2007 | 07:49 PM
MorpheusZero's Avatar
I'd be surprised if those didn't rub the strut housing... keep us informed.
Old Jun 14, 2007 | 07:48 AM
freddorais's Avatar
I didnt bought the tire yet , will i be able to know if thy rub without the tire ?
Old Jun 14, 2007 | 09:24 AM
carnal_c30's Avatar
Former Sponsor
the 18x9s 45mm offset on 255/35s will rub on the inside fender when you turn on a fourth gen
Brian what wheels are you rockin on your 5th gen?? 19x9??
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
Garrettz459
Aug 29, 2015 02:18 PM
