Rotating uneven tire to rear... any harm?
Old Jul 16, 2007 | 06:06 PM
hito's Avatar
I was looking at my tires the other day and noticed that the front passenger tire is wearing unevenly. The inside of the tire is wearing more than the rest of the tire.
Is it okay to move the tire to the rear and get an alignment? As in, will I be damaging or wearing out some components in the rear by rotating my tires and giving it a "bad" tire.
I kind of like buying 4 new tires at the same time, so I was thinking of trying to get the most out of the rear tires before having to change to a new set... That is if it's not damaging any other components.
Old Jul 16, 2007 | 06:27 PM
z32drifter's Avatar
It's not going to damage anything. As long as the tire is just worn and there is no other damage to the tire, it should be fine.
Old Jul 17, 2007 | 07:46 PM
hito's Avatar
Yah, it's just really unevenly worn. Was just afraid that it was going to wear out some suspension components by placing the tire back there. But if it's okay to do so, then I think i'll just rotate them some time soon.
Old Jul 20, 2007 | 12:15 PM
slc02max's Avatar
You should be fine, but you may want to have the tires with the most tread on the front. Keep an eye on it, and make sure there are is no metal showing through the tire.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
