rim size ?
Old Sep 5, 2007 | 12:36 AM
ATmax99gle's Avatar
rim size ?
i want to get 18s and debating if i should get 18x7.5 +42 offset or 18x8 +45 offset which is a better fit for the car? thanx
Old Sep 5, 2007 | 04:38 AM
MDeezy's Avatar
this maybe better in the wheels and tire section.
Curious if youd have rubbing issues with the 45 offset 8" wide wheels....
Old Sep 5, 2007 | 04:49 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Not with 35mm offset
Old Sep 5, 2007 | 04:53 AM
MDeezy's Avatar
would 35 stick out too far? or sit pretty flush with the fender?
Old Sep 5, 2007 | 10:00 AM
Fast1one's Avatar
+35 will be close to flush with an 8 inch wheel, close enough if your scared of rubbing your fender
Old Sep 5, 2007 | 09:22 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showpost.ph...61&postcount=2
http://forums.maxima.org/showpost.ph...06&postcount=2
http://forums.maxima.org/showpost.ph...74&postcount=2
http://forums.maxima.org/showpost.ph...11&postcount=5
Old Sep 6, 2007 | 12:43 AM
ATmax99gle's Avatar
will 18x7.5 +45 offset work?
Old Sep 6, 2007 | 04:35 AM
MDeezy's Avatar
seems like it will work but there is a good chance you'll need spacers. Only way to know for sure is to either measure or wait for someone who has the excat size wheels on their car to chime in.
Old Sep 6, 2007 | 05:59 AM
NmexMAX's Avatar
dot dot dot ...
+ 15mm rear spacers and 5mm Fr spacers.
Old Sep 6, 2007 | 08:50 PM
ATmax99gle's Avatar
i want to avoid spacers so do i find 18 x 7 rims?
Old Sep 15, 2007 | 03:54 PM
NmexMAX's Avatar
dot dot dot ...
7" = too thin.
Old Sep 15, 2007 | 07:37 PM
z32drifter's Avatar
Originally Posted by NmexMAX
7" = too thin.
2nd 7's are for Civics, if your going to spend the money to upgrade go with 8s or larger. I would go with a 8.5 +40 all around, and run a 10mm spacer in the rear.
Old Sep 15, 2007 | 07:42 PM
NmexMAX's Avatar
dot dot dot ...
Advice doesn’t get much better than this.
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
knight_yyz
Nov 1, 2015 01:34 PM
