350z rims on 4th gen
Old Oct 8, 2007 | 04:00 PM
one_fast_max's Avatar
i have been trying to look and find any info of 350z 18'' 5spoke rims on my 97 maxima. my car is lowered two inches. i don't know too much about rim sizing so would yall help me? do i need spacers....will this work? does any one have a picture of some one with these rims on their 4th gen? thanks!!
Old Oct 10, 2007 | 02:04 PM
no one have any pics?
Old Oct 10, 2007 | 03:49 PM
z32drifter's Avatar
IIRC the 350Z wheels are 8 +30 front and 8.5 +33 rear. They should be fine.
Old Oct 10, 2007 | 04:18 PM
hey man thanks for the info! i was wondering if i should buy 4 front rims or 4 rear rims to keep the width the same. what would yall suggest?
Old Oct 10, 2007 | 04:41 PM
IHAVEA2KMAXIMA's Avatar
If you keep them the same width then you can rotate your tires. But it's kinda hard to find 4 same wheels that are in similar condition alway.
Old Oct 10, 2007 | 05:35 PM
!PrjctMax!'s Avatar
It took me roughly 3 months to find 2 sets so that I could have 4 fronts and NmexMAX could have 4 rears
Old Oct 10, 2007 | 05:54 PM
ah i see.....but i guess four of the same is better. should i run four 8.5 or four 8.0?? would that be a 235/35R18?
Old Oct 10, 2007 | 06:02 PM
White Shadow's Avatar
Still chugging along...
I don't have the 18s but I have a staggered set of 350Z 17s. the fit perfectly with no spacers. I tried a set of all 7.5" (fronts). I like the staggered fitment better even though the car is FWD. I get lots of compliments on them. I actually got the same size tires on all four wheels so I can rotate them but have to have each wheel/tire broken down to rotate the tires without changing the wheel locations.
Old Oct 10, 2007 | 06:34 PM
I would say screw it and go stagger (which I myself did). First of all... are you lowered? I'm pretty sure you would be fine in the back with 8.0 + 235 with 30mm offset but front would probably gonna have problems (rubbing). So.. 8.5 is out of the question -IMO-.
Old Oct 10, 2007 | 09:14 PM
!PrjctMax!'s Avatar
I have 4 18x8 with 245/45/18 on them and they are sweet!
Old Oct 10, 2007 | 10:44 PM
do you have a pic of your car? i would love to see that set up....that's most likely what i will do.
yes IHAVEA2KMAXIMA i am lowered two inches all around.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
Hdnseek
Sep 9, 2015 05:55 AM
adamgalazka
Sep 8, 2015 01:27 PM
Lowered_a33
Sep 1, 2015 07:49 PM
