Looking at rims, offset Q.
Old Nov 1, 2007 | 04:58 AM
toastedoats's Avatar
I am looking into buying a set of winter rims used. THey came off of a G35 coupe, and are 17x7.5 with a +32 offset. Could anyone tell me if i will have any rubbing issues? I currently have my coilovers set with a 3" drop, so i dont know if the smaller offset will cause issues
Old Nov 1, 2007 | 06:13 AM
BLACKonBLACK98's Avatar
Former Vendor
you'll be fine.
Old Nov 2, 2007 | 10:11 AM
MrDicks95SE's Avatar
Offset Is Everything.
it will fit no problem. no rubbing issues.
Old Nov 2, 2007 | 10:35 AM
Fast1one's Avatar
Fitment issues with offset are directly related to the width of the wheel, just because an offset is low doesn't mean that it won't fit..
I can have a seven inch wheel with a +13 offset, because the width is significantly smaller than say, a 9 inch wheel, the added clearence will allow me to run a lower offset to be flush with the fender.
This is why we have the offset calculator at the top of the page, it does the work for you...
I think we should add this note the offset calculator, based on the observations I have of setups on 4th gen maximas (5th and 6th can add their 2 cents later... )
For a fourth gen Maxima and a moderately flush setup in the front (little/no poke, I believe 3mm), roll rear fender and space to match:
Width Offset Tire Size
9 +38 255
8.5 +32 245
8 +25 235
7.5 +19 225
7 +13 215
You can vary the offset a little, but I don't recommend going too much lower if you don't want to stretch tires too much to fit. The tire sizes are also not concrete, but I don't recommend going too much bigger because of rubbing issues, especially if your slammed...
Moderators, do you think you could add that? I see offset threads weekly now it seems, would be nice Maybe add read before asking question in title
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
0m3nc0w
Sep 11, 2015 05:21 PM
