what spacers to get with +50 offset...
Old Dec 20, 2007 | 10:10 AM
hotstartup's Avatar
what do you guys recommend with the frnt and the rear, with +50 i fear it'll stick too far in.
also wat lug nuts would you recommend for is300 rims which are shank style
Old Dec 20, 2007 | 11:43 AM
Fast1one's Avatar
Depends on the width of the wheel...
Old Dec 20, 2007 | 11:49 AM
hotstartup's Avatar
its 7.5 wide.
Old Dec 20, 2007 | 12:07 PM
00SEMAX19's Avatar
I would say at least 15mm spacers all the way around for a decent look.
As for lug nuts, the IS wheels require a shank style lug with a washer. I'd say use the lexus lugs but the maxima has a different thread pitch. The IS300 thread pitch is 12x1.5 and the maxima is 12x1.25. I would go to some local tire shops and see what they can get you. Maby try contacting these guys and see what they can get you.
http://www.gorilla-auto.com/vehicleSearch/
Old Dec 20, 2007 | 01:34 PM
hotstartup's Avatar
thanks max19 how are these?
http://cgi.ebay.com/ebaymotors/12mm-...spagenameZWDVW
Old Dec 20, 2007 | 05:17 PM
00SEMAX19's Avatar
Originally Posted by hotstartup
cheap! They are not hubcentric and usually cause vibration issues. You will be much happier if you step up and get some H&R or Eibach brand spacers.
Old Dec 20, 2007 | 05:51 PM
hotstartup's Avatar
i dont think i wanna spend 200 bucks on the H&R kit, what if i just go +5mm it'll make it close to oem, without the added expense.
can you link me to one you think will work best, and give me enough thread to get the lugs on properly
Old Dec 20, 2007 | 06:10 PM
00SEMAX19's Avatar
I have a pair of H&R 15mm spacers I'll sell ya if you want. They are just spacers without studs but are hubcentric and have never been installed on a car.
$40.00 plus shipping so probly $50.00 shipped.
I can take pics if you are interested
Old Dec 20, 2007 | 06:13 PM
00SEMAX19's Avatar
Here you can find many options.
http://autosportstyle.com/shop/nissa...s-p-58232.html
Old Dec 20, 2007 | 10:22 PM
Fast1one's Avatar
Please look into other wheels, to be flush with the fenders you would need 25mm spacers for the front, and 40mm for the rear, screw that
For 4th gen that is, probably more for a 5th gen
Edit: BTW IIRC Toyota bore size is 60.1 vs. Nissan's 66.1. Pretty sure its the same for Lexus, search to make sure, but it looks like the decision was made before you could try
Old Dec 21, 2007 | 12:22 AM
hotstartup's Avatar
they are bored to 70.1 and i already have the hub rings. whats a good offset to have to have the rims sit flush. i think ur right on the idea of trying other wheels. lol
Old Dec 21, 2007 | 02:34 AM
00SEMAX19's Avatar
+30 or maby +35 offset should sit fairly flush. maby 35 for front and 30 for rear.
+1 on the find other wheels.
Old Dec 21, 2007 | 10:24 AM
hotstartup's Avatar
wont have any issues with rubbing either right if i go +35 with a tiny drop
Old Dec 21, 2007 | 11:36 AM
00SEMAX19's Avatar
No, that should be fine
Old Dec 22, 2007 | 12:54 PM
NmexMAX's Avatar
dot dot dot ...
First off, why would get wheels that are +50?
I’d vote for 25mm In the rear and 20mm in front on those (+50/7.5 wide).
Old Dec 22, 2007 | 02:11 PM
MrDicks95SE's Avatar
Offset Is Everything.
+1, omg yeah why would you get +50 offset wheels in the first place?!
Old Dec 22, 2007 | 03:54 PM
maxspeed96CT's Avatar
The original VQ...
50 offset?? is that for a geo metro??
id pay extra and get some rims thats are at least 8" wide and a 35- 40 maybe even 42 offset
Old Dec 22, 2007 | 05:52 PM
Fast1one's Avatar
I would go more, but this would be perfectly acceptable...
150-200 dollars in spacers FTL...
Old Dec 22, 2007 | 06:12 PM
hotstartup's Avatar
they are off my other car, went on my legend and it fit perfectly and looked great, stock offset on the legend was 55!
i think i am gonna go +35 around on the max
Old Dec 22, 2007 | 07:37 PM
Fast1one's Avatar
Don't forget, the different widths will require different offsets, 8 inch wheels sit just about flush with the front with a +25 offset, and flush with a 10mm spacer in the rear, just use the offset calculators and use that as your base
incubusjohnny
Nov 3, 2015 05:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Lowered_a33
Sep 10, 2015 09:41 PM
Maxboy23
Sep 4, 2015 06:04 PM
Maxboy23
Aug 11, 2015 11:59 AM
