Need MORE help with offset?
Old Jan 4, 2008 | 12:49 AM
Fr33way™'s Avatar
Wild for Width
Try this link, comprehensive comparison of what you have and what you want.
http://www.rims-n-tires.com/rt_specs.jsp
Old Jan 4, 2008 | 05:45 AM
ROCKART's Avatar
wants an I35
thats cool. thanks
Old Jan 4, 2008 | 08:28 AM
BLACKonBLACK98's Avatar
Former Vendor
i think the 1010tires.com one is simpler but the graphics make this one pretty awesome. good find.
Old Jan 4, 2008 | 10:05 AM
Fast1one's Avatar
That is pretty cool, but I still think someone should just sticky a list consisting of the different widths and their respective tire sizes/offsets...
I posted something like that earlier...but no one seemed to care These sizes are for a fourth gen, spacer in the back would be needed...
I think we should add this note the offset calculator, based on the observations I have of setups on 4th gen maximas (5th and 6th can add their 2 cents later... )
For a fourth gen Maxima and a moderately flush setup in the front (little/no poke), roll rear fender and space to match:
Width Offset Tire Size
9 +38 (255)
8.5 +32 (245)
8 +26 (235)
7.5 +20 (225)
7 +14 (215)
You can vary the offset a little, but I don't recommend going too much lower if you don't want to stretch tires too much to fit. The tire sizes are also not concrete, but I don't recommend going too much bigger because of rubbing issues, especially if your slammed...
Obviously the aspect ratio would vary depending on the diameter of the wheel...
Old Jan 4, 2008 | 01:02 PM
DrKlop's Avatar
Driving is the next best thing
Very nice! Makes calculations much easier!
Old Jan 6, 2008 | 11:31 PM
Fr33way™'s Avatar
Wild for Width
I thought the visual aspect would be easier for some people.
Old Jan 7, 2008 | 08:39 AM
Former Vendor
if only it would stretch the tire...
Old Jan 7, 2008 | 09:00 AM
zero2sixtyZ's Avatar
You embarrass me.
nice find. definitely helps for people to understand offset, as well as wheel/tire sizing. i do like the descriptions for everything underneath explaining the changes.
Old Jan 11, 2008 | 01:02 AM
Delvin's Avatar
Good find!! I've seen this one before and noticed that it gave a bit more info than most other offset/tire calculators. It has a problem with people wanting to run stretched tires. I can't put 225/35/19s on a 19x9 on their calculator.
Old Jan 11, 2008 | 04:05 AM
00SEMAX19's Avatar
Stretching the tire = Too small of a tire for the rim =
But if looks and unreliablity is what people want then go for it...
Old Jan 11, 2008 | 08:32 AM
Former Vendor
sunk in wheels and/or rubbing =
no rear camber =
stretched tires = dealing with the
personally, i don't care for the look (which is why a lot of people do it), but if i have to do it to get low and run flush wheels then i will.
Old Jan 11, 2008 | 09:39 AM
Fast1one's Avatar
no rear camber =
In addition to the above, you won't notice the stretched tires too much if you radius the fenders and drop the car down to the lip
Old Jan 11, 2008 | 11:04 AM
!PrjctMax!'s Avatar
that's some good stuff!
Can we also compare that to adding spacers? As in, I have a 30 offset and if I get 15 spacers making it a "15" offset?
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
