Pix request +35F/+35R with springs.
Old Feb 3, 2008 | 12:26 AM
perrymaxima's Avatar
Does anyone have pictures of their 4th Gen. or 5th Gen. Maxima or I30/35 with any size rims with a +35mm offset front and back? I am going to buy a set of MRR HR2 in +35 front.
http://forums.maxima.org/showthread.php?t=545781
I need to figure out which springs to get to finish the look since with these offsets they will be pretty flush with the fenders. I been looking around in the 5th Gen. I30/35 forums but couldn't find pictures of cars with these specs. Include your spring/strut setup in your post.
Old Feb 3, 2008 | 03:01 PM
z32drifter's Avatar
I have a set of 17x9 +34 wheels I used for track tires. I recently bought new track wheels, so they are back on the Maxima. Here's some old pictures with S-tech springs.
they have 275/40 race tires in these shots, the front sticks out less with a smaller tire but it's still out 5-6mm with a 9" wheel.
here's an action shot with 255s
for the flush look I like this setup 8.5 +40 front and 9.5 +38 rear (a 9 +35 is flush in the rear with larger tires)
Old Feb 4, 2008 | 03:02 AM
^ Thanks for the pixs S tech is too low I still need some fender gap since the I35 is going to be more the commuter car.
Old Feb 4, 2008 | 03:23 AM
MorpheusZero's Avatar
Here are some 8.5" +35s. the tire will stick out less if you have a 19" rim rather than a 16, making the appearance a bit more sunk in. The car is on Eibachs.
Old Feb 4, 2008 | 07:09 AM
BLACKonBLACK98's Avatar
Former Vendor
heres a pic of a 9.5 +35mm rear on a 4g. the pic morpheus posted is a perfect example of the front.
AcuraLegend
Oct 17, 2016 08:47 PM
imported_Nismo_max
Feb 17, 2016 03:39 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
AcuraLegend
Sep 22, 2015 04:22 PM
