Tires that wont rub?
Old Feb 10, 2008 | 08:42 PM
Camfantasy's Avatar
I'm kind of new to buying tires (20 and never bought a single tire, ha) i have a 99 SE-l, it has s-tech springs, 2" drop all around i do believe and it has G35 5 spoke 17's on it. I'm experiencing some rubbing on the 215/55/17s turanzas that came on the car, but what im asking is where should i change the size at in the tire to avoid rubbing if i want to keep my 17s and springs? thanks
Old Feb 10, 2008 | 08:50 PM
Fast1one's Avatar
Find out where its rubbing, small tires will not solve all your issues...if its in the rear outer fender lip then you can roll your fenders to remedy that...we can't really give you suggestions over a computer screen, its just impossible....
Old Feb 10, 2008 | 08:57 PM
Camfantasy's Avatar
so like 215/50/17s wouldnt help eliminate the problem, i think its like the inner fender well on the front tires. i mean its not like terrible rubbing jus a little when turning ya know?
Old Feb 10, 2008 | 10:44 PM
Fast1one's Avatar
I doubt its the inner fender liner, you mean the inside of the OUTER sheet metal? (the part thats painted). Because I am running 18 x 9.5 +35 with 245/40s and a 1.7 inch drop and I have NO rubbing...
Old Feb 11, 2008 | 06:35 AM
NmexMAX's Avatar
dot dot dot ...
The tires are too big. 215-50's or 225-50's
Old Feb 11, 2008 | 03:44 PM
Camfantasy's Avatar
what pro's and cons would this have on my ride quality, handling and treadwear if any?
Old Feb 11, 2008 | 05:37 PM
NmexMAX's Avatar
dot dot dot ...
None, aside from maybe a little bit stiffer ride but no rubbing problems. Tread wear is not affected.
Old Feb 12, 2008 | 02:25 PM
Camfantasy's Avatar
alright, thanks for the help
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
