optimal offsets?
Old Feb 10, 2008 | 11:29 PM
dutch078's Avatar
keep it metal
optimal offsets?
my head is spinning from all the threads and posts i've just read on wheel offset. it still throws me for a loop every now and then! anyway, regarding the 4th gen, is there an ideal offset that will offer the best look and proper handling? it seems that most of what i came across suggested that an offset of +40 is acceptable. is there a range of offsets that are a good guideline? are there offsets that should be avoided or are less desireable? i understand that wheel width plays a factor as well; i'm just looking for a good guideline to go by. thanks in advance.
Old Feb 11, 2008 | 06:34 AM
NmexMAX's Avatar
dot dot dot ...
in order for the fronts and rears to be flush and not going staggered, you will need a 15mm spacer for the rear and about a 5mm for the fronts. This is assuming +40 & 8" wide.
Old Feb 11, 2008 | 06:48 AM
BLACKonBLACK98's Avatar
Former Vendor
instead of looking for the answer to a generic question, i would suggest reading up on wheel construction and what all the numbers mean. once you really understand it its the simplest of math.
Old Feb 11, 2008 | 09:50 AM
Fast1one's Avatar
x2....
Old Feb 15, 2008 | 09:44 PM
dutch078's Avatar
keep it metal
i've been reading up the past few days - it's a lot clearer now.
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
