Will these fit? Please help...
I am looking to get a set of black rims for my 4th gen non lowered 96 GXE. They are 18x9 with a 38 offset. They are only $330. Do you think they will fit? Any rubbing issues? Also what would be the perfect tire size for such a rim? You're input would be much appreciated.
They will fit fine...255/40s or 245/40s would work great...
Wheels are 18 x 9.5+35 with 245/40s...these DO stick out
http://s28.photobucket.com/albums/c227/Fast1one/Maxima/
i think they will stick out more than a mm or two.
think stock wheels are 6.5 inches wide with 40mm offset. so the 2mm you can disregard.
they will be 2.5 inches wider than your stock setup *(plus 2 mm)
nope. 2.5mm is correct. we don't call him mister fitment for nothing.
they will be 2.5 wider but only half of that is to the outside of the wheel (1.25"), which happens to be just about the same amount that oem wheels are recessed.
to the op. i would be surprised if anything rubbed at stock height, but 255 would be the highest i would go for aesthetic reasons.
Funny thing, I just do it in my head now...I was like meh 1-2mm is about right
They will probably will stick out a mm or two in the front, which won't really be noticeable...the rear will be sunken in 10-15mm, which is kind of a good thing because it won't rub the fender...If it does you may have to roll your fenders, but I really doubt it...if you are afraid of rubbing just to 245/40s...
or you can use a fender roller...245/40s should be great...
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
