question on rays
Old Apr 10, 2008 | 05:02 PM
hotstartup's Avatar
question on rays
the rear offset is 33, while the front is 30. is it better to swap these around when putting them on my max?
here are the detailed specs
Front Size: 18x8.0 Offset: +30mm Weight: 18.19lbs Tire: 225/45/18 Rear Size: 18x8.5 Offset: +33mm Weight: 18.62lbs Tire: 245/45/18
Old Apr 10, 2008 | 05:18 PM
SoonerFan's Avatar
Cletus
you could have found this by searching....or posting in the wheel forum
i have the Z 17s....i have the wider ones up front
Old Apr 10, 2008 | 09:00 PM
MrDicks95SE's Avatar
Offset Is Everything.
recommend rotate front to back only. no cross rotation. can be rotated side to side if symmetrical tires.
Old Apr 10, 2008 | 10:02 PM
hotstartup's Avatar
sounds good. ill put the higher offset in the front. thanks guys.
Old Apr 11, 2008 | 07:45 AM
hotstartup's Avatar
i can reuse the stock lug nuts right?
Old Apr 11, 2008 | 10:17 AM
BLACKonBLACK98's Avatar
Former Vendor
i wouldn't put the wider up front but thats me.
Old Apr 11, 2008 | 10:21 AM
yes. why wouldnt you?
Old Apr 11, 2008 | 05:22 PM
hotstartup's Avatar
put them on today. I did put the wider ones in the rear, the front stick out a tad. Mr****s, i wasnt sure if the stock lugnuts would work as the rims are different and may have had a different grooving. But after looking at the rays, it looked like both were the same.
i think its best if the +33 offset is in the front, and the +30 in the rear, otherise the front would stick out too much. need a drop! and new tires. the bridgestone potenza re040 suck, very very noisy. the tires i have on now are 225/45/18. i think ill probbably go with 235/40/18 next. this should be within spec.
Old Apr 11, 2008 | 05:42 PM
the only difference in lug nuts is the thread pattern. maybe open ended or closed ended as well but thats pretty much it.
thats why they're called craptenza's. not a very likable tire. plus the size itself is taller and wider than what you really need. get a better tire with the right size and you should be good to roll.
Old Apr 11, 2008 | 05:47 PM
hotstartup's Avatar
what brand and size tires would you recommend? 235/40 is what i was thinking for size if you recommend something else id look into it some more..
Yoko Avid 4s look promising.
Old Apr 12, 2008 | 02:14 AM
NmexMAX's Avatar
dot dot dot ...
Dunlop / Yokos / Pirelli / etc:
http://forums.maxima.org/showpost.ph...1&postcount=74
Old Apr 12, 2008 | 03:06 PM
Puppetmaster's Avatar
IMO, it doesn't really matter, but might look weird because your tire sizes are different. I really doubt the 3 mm in offset will make a difference. The rears are also .5" wider. +30mm in the front is fine, but if you want the rears to come out more, just get some 5 mm spacers or even 10 or 15 mm.
As for the lugs, I assume when you say "stock" you mean the stock Z lugs? I think the stock Maxima lugs are too big for the Tracks. They may fit, but it'll be tight IIRC and you may risk scratching up the rims whenever you remove or mount them.
Old Apr 12, 2008 | 03:13 PM
NmexMAX's Avatar
dot dot dot ...
Tuner Lugs FTW
Old Apr 12, 2008 | 03:23 PM
Originally Posted by NmexMAX
Tuner Lugs FTW
LOL... nice. I'm using the stock Z lugs on mine, but if I find a good deal on some blue Rays lugs...
Old Apr 12, 2008 | 05:09 PM
hotstartup's Avatar
i actually want the fronts to stick out less. Maybe it was a bad idea swapping the fronts and the rears (since you said the rears are about 0.5" wider) ill change them around. I am using the stock maxima lugnuts on the rays right now. which lugs do you recommend?
the tires on their now are 225/45 all around.
Old Apr 13, 2008 | 06:39 PM
NmexMAX's Avatar
dot dot dot ...
Wow, that is a thin tire for 8.5" wide.
Old Apr 13, 2008 | 06:42 PM
hotstartup's Avatar
yea, it is pretty thin, but it came with it so couldnt do much about it. 235/40 good?
Old Apr 13, 2008 | 06:45 PM
NmexMAX's Avatar
dot dot dot ...
I'd go w/ 245 - 40.
Old Apr 14, 2008 | 10:25 AM
!PrjctMax!'s Avatar
Front is 8'' and rear is 8.5''
Front tires for those are 225 and rears are 245...come on now Manny, we've been through hell and back with these wheels, you should at least know the sizes of them!
Old Apr 16, 2008 | 06:31 AM
NmexMAX's Avatar
dot dot dot ...
I tend to block out the fact that they are staggered since mien aren't
Old May 1, 2008 | 12:00 PM
hotstartup's Avatar
i think im gonna go with 235/45/18 what do you guys think? buddy at a shop told me i should get 225/50/18.
the 235/45 puts it right on spec with oem, but not sure if it will rub wiht a 1.5 drop
Old May 1, 2008 | 07:33 PM
hotstartup's Avatar
I'd go w/ 245 - 40.
isnt that even thinner? tire calc shows smaller sidewalls and diameter
Old May 1, 2008 | 07:43 PM
RacerX1320's Avatar
Or you can READ MY SIG. HAHA
Old May 1, 2008 | 08:01 PM
hotstartup's Avatar
cant afford new lug nuts right now need new tires!
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
