help will these fit? 19x9 40 offset on 5th gen.
Old Jun 5, 2008 | 08:49 AM
dat01max's Avatar
hey guys im looking at getting a set of wheels with a 40mm offset thats 19x9....will these fit on the 2k2 while running a 245/35/19 tire without problems???
they come in 19x8 tho also but i want^^^
Old Jun 5, 2008 | 10:04 AM
Kyle00's Avatar
WSH for teh cup
wheels/tires forum
Old Jun 5, 2008 | 02:04 PM
Torgus's Avatar
i think you would rub unless you roll your fenders.
if run 245s i rub...
Old Jun 6, 2008 | 08:41 AM
dat01max's Avatar
you dont have your fenders rolled?
Old Jun 6, 2008 | 08:47 AM
NmexMAX's Avatar
dot dot dot ...
+40 9" wide. I don't think. I have 8.5" + 18mm and only rub on 1 side on horrid bumps due to my beam being
Old Jun 6, 2008 | 08:53 AM
maxima.713's Avatar
YUP. ROLL YOUR FENDERS
Old Jun 6, 2008 | 05:02 PM
ICEMAN76's Avatar
Anyone have a pic of rolled fenders??
Old Jun 6, 2008 | 05:18 PM
SoonerFan's Avatar
Cletus
search
Old Jun 6, 2008 | 06:30 PM
dat01max's Avatar
so as long as i roll the fenders then i can fit it
Old Jun 7, 2008 | 03:13 AM
LeX's Avatar
LeX
Nissan by Nature
also depends on your drop.... ur not gonna rub if drop isn't severe.
Old Jun 20, 2008 | 08:53 AM
hi-tek22's Avatar
Ive got a mild drop on H&R Springs....im running 245/35/19 tires and 19 inch rims with a +38 offset
Does any one think ill begin to rub over time...so far i dont think im rubbing, i dont see any damage or anything on the tires....in the rear, but as time goes on do you guys think ill be ok
Old Jun 20, 2008 | 08:59 AM
NmexMAX's Avatar
dot dot dot ...
I'm on 8.5" +18 and rub on very rare occasions. W/ the +38, I'd say you're fine.
Old Jun 20, 2008 | 11:19 AM
MrDicks95SE's Avatar
Offset Is Everything.
werd. youll be fine.
Old Jun 25, 2008 | 12:16 PM
Shadow's Avatar
You'll likely be fine. I was running 19x9 +30's on my 4th gen with 255/35's and only experienced mild rubbing on one side in back. Tire profile will also have a little bit of an effect on whether or not you rub. But with a +40, I wouldn't worry.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
