225/40/18's Vs 235/40/18's tires
Old Dec 18, 2008 | 01:06 AM
shook187's Avatar
I did a bit of searching and couldn't help but notice guys using those size tires when running on 18" wheels. What problems will I run into by choosing one size vs. the other. BTW...The 225's are so much cheaper than the 235's, which is why I'm leaning buying
Old Dec 18, 2008 | 01:33 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Seems as though most with 8" wide wheels are running the 235/40 version (I am).
Old Dec 18, 2008 | 06:56 AM
MrDicks95SE's Avatar
Offset Is Everything.
you wont run into any problems besides the fact that one is slightly wider than the other. wheel width, offset, ride height are things you need to specify to get a better answer.
Old Dec 18, 2008 | 11:27 AM
Snypa's Avatar
Old Dec 18, 2008 | 03:01 PM
IlyaK's Avatar
The Golden One
Yeah...
I am 18x7.5 and went 225/45/18.
I think you'd be okay...
Old Dec 19, 2008 | 12:53 PM
NmexMAX's Avatar
dot dot dot ...
How wide are the wheels?
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
