.6 lbs or .5" for track wheels?
Old Oct 8, 2009 | 02:56 AM
MIK3's Avatar
Looking for track wheels later down the road and am pretty convinced I'll be doing two 17" Enkei RPF1's up front. My two options:
17x9 @ 15.9lbs
or
17x9.5 @ 16.5 lbs
Which set up would be more advantageous? I'm not sure how a reduction in 1.2 lbs would compare to 1 more inch of tire on the track. Thanks in advance.
Old Oct 8, 2009 | 11:56 AM
Matt93SE's Avatar
STFU n00b!
go for more tire.
Old Oct 10, 2009 | 08:54 PM
MrDicks95SE's Avatar
Offset Is Everything.
go with the 17x9.5 and run more rubber.
Old Oct 12, 2009 | 03:27 AM
MIK3's Avatar
So I have two for more tire. I was feeling this way as well. Am starting to wonder if there will be an issue with fittment...
Old Oct 12, 2009 | 05:14 AM
Crusher103's Avatar
tires are going to weigh between 20-25lbs anyway so just go for the wider wheels, .6lbs is not going to make a difference.
Old Oct 12, 2009 | 10:44 PM
offsets man, list the offset.
Old Oct 12, 2009 | 11:06 PM
Fast1one's Avatar
17x9.5 +35-38 is PERFECT with 2 degrees of camber in the front. Roll fenders to fit.
Old Oct 13, 2009 | 12:17 AM
MIK3's Avatar
Ah, sorry about this.
17x9 = 38
17x9.5 = 35
I believe these are the only offsets available for these specific sizes.
Old Oct 13, 2009 | 07:25 AM
Fast1one's Avatar
17x9 = 38
17x9.5 = 35
Do it, the latter will fit perfect for wide rubber.
By the way, those are NOT the only offsets for those sizes unless they have been discontinued. Pretty sure they were special order, but you can get pretty low...
t6378tp
Sep 29, 2018 04:27 PM
Bonka
Sep 14, 2015 11:18 PM
