Dunlop Super Sport Race tires - 350$ for a set, brand new...should I?
Old Jun 2, 2010 | 01:06 AM
shadyonedeath's Avatar
I have 2 choices:
Dunlop Super sport race ( i cant even find these on tirerack..whats the real name?)
I know the tread wear sucks (60) but can I really get a better deal on new tires than this? 350$ for a set of four.
What do you think?
or Falken Zien ZE912 ? Same price but claim to be used for 300 miles.
Old Jun 2, 2010 | 04:08 AM
SteveB123's Avatar
3/4 of Dunlop's performance lines are called "Sport", so you'll have to be more specific.
What are you using the tires for? Track only?
Old Jun 2, 2010 | 06:43 AM
Go with the Falkens.
Old Jun 2, 2010 | 08:14 AM
street. Not track.
Old Jun 2, 2010 | 09:02 AM
NmexMAX's Avatar
dot dot dot ...
Treadwear of 60? Are you sure it isn't 160?
size are they?
Old Jun 2, 2010 | 09:46 AM
all 225 40 18.
Thats the the ad says, 60, A, A, Z.
Old Jun 2, 2010 | 09:51 AM
SteveB123's Avatar
Maybe if you don't drive much, I guess....but trying to save money by buying things that wear out quickly doesn't work.
Old Jun 2, 2010 | 10:07 AM
NmexMAX's Avatar
dot dot dot ...
counterproductive.
IMO, 225-40 18 on a 4th gen might look a wee bit flimsy/thin and too low pro, but that's IMO, as I like to have my fender well look somewhat filled.
Old Jun 2, 2010 | 03:33 PM
for 18" x7.5" muranos?
Old Jun 3, 2010 | 12:05 PM
NmexMAX's Avatar
dot dot dot ...
A32's can get away with 235-40-18's for a decent look, and that will be fine on those wheels.
Old Jun 3, 2010 | 01:04 PM
so 225 is a no no? I had a 225 fitted on the muranos to see how it would look on my car and it looked normal to me.
Someone explain to me the "cons" of running the 225/40/18 falken.
thanks for your replies btw, much appreciated.
Old Jun 3, 2010 | 06:02 PM
Nealoc187's Avatar
SLOW
Dunlop SP Super Sport Race, you can't find them because they are an old tire. Appears they came out in 2004. Found a couple forum threads about them with pics, and that is definitely the same tread pattern.
http://forums.rennlist.com/rennforum...tire-rack.html
Ask the seller to take a pic of the manufacture date on the sidewall, or just go look at them if they are close. I don't know how long they were produced for, so they might be from as early as 04, but they might be from later like even 06 or 07, depending on how long dunlop made that tire. You should find out before you make a decision.
Problem with old tires is that the rubber loses it's elasticity, starts to dry rot, etc. If they were stored out of sunlight they might be OK(and I see you're in california so you don't have to worry about cold like we do up north, cuz storing tires in a below freezing garage in winter will harm the rubber too).
So basically that Dunlop was a very high end tire, but that was a number of years ago. They won't last you very long (very sticky and very low tread wear, they are an R compound tire). Depending on how much the rubber has deteriorated because of how they were stored, they could still be pretty damn sticky, or they could be dry rotted to hell and not worth it at all.
Old Jun 3, 2010 | 06:03 PM
SteveB123's Avatar
It's a grand total of 0.2" less in diameter.
Old Jun 3, 2010 | 09:27 PM
I bought the 225/40/18 Falken 912's. They came off a Mercedez Benz because he didn't like how thin they were so he went for 225/45/18. Tires look brand new! I got them for 300$
months and months of searching finally paid off.
Pics soon as i finish painting the muranos.
Old Jun 4, 2010 | 06:31 AM
NmexMAX's Avatar
dot dot dot ...
The width is what I was caring about, and tires differ, brand to brand. Don't really care about dia. As for width, again on paper, it's 10mm wider, but I once measured a 2.5" difference in some Yokos and Dunlop 245's. One rubbed like a ****, the other not so much.
Well good shady, you got some tires.
Matt93SE
May 24, 2019 02:58 PM
MississippiMax
Sep 26, 2015 08:30 PM
tothemax2003
Wheels/Tires
Sep 1, 2015 06:01 AM
NissLover
Aug 22, 2015 10:26 AM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
