Upgrading from 17" OEM Wheels to 18" OEM wheels
I have a 2002 Maxima and and am trading in the 17" wheels for some 18" wheels. After searching, I believe that I want a 40 profile tire, correct?
I want to make sure that the diameter of the new wheel package is no larger than othe old (i.e. don't want rubbing, or speedo problems). Long story short, 45 profile will not work, am I right??? Thanks Guys. |
245-40 seems to be a favorite on an 8 or 8.5" wheel.
What is the offset and width of the wheels and what is your suspension set-up? |
45 will work...but its supreme bubble gum bubble yum status. 40series IMO is perfect. i ran 245/40/18s when i had my G35 wheels on and loved it...went to 235/40/18...long story short, i traded them wheel/tire for another set of wheels and tires as i wasnt liking how it looked
245/40/18 http://i45.photobucket.com/albums/f7...d/100_1356.jpg |
(Post 7715006)
245/40/18 http://i45.photobucket.com/albums/f7...d/100_1356.jpg What looks better on OEM Infiniti wheels, 40 or 45 profile? What matches the oem diamater on a 18", 40 or 45 profile? |
i dont know if you can see in this pic too well..but thats 245/45/18 tire that was on the G wheels when i first got them
http://i45.photobucket.com/albums/f7...d/IMG00062.jpg i quickly got rid of them for the 245/40/18 tire....'bubble gum' status is just a term for a high profile tire opposed to a lower profile...my personal terminology. if i'm correct, i beleive 245/40 corresponds to the factory spec as far as overall diameter to the 17" oem wheel/tire combo |
tirerack.com gives you the comparison of sizes to make sure you get as close as you can on OEM diameter size.
Originally Posted by mandyfig
(Post 7715125)
that seems too high, but i guess numbers dont lie
1010tires.com has a good tire calculator that you can compare stock size to any plus size. All you have to do is punch in the sizes you want to compare and it will give you all the info you need. If you are looking for speedo accuracy, a 245/40/18 would be the closest match. Check it out!!
http://www.1010tires.com/tiresizecalculator.asp |
Originally Posted by sensfan1111
(Post 7715891)
(Post 7715125)
(Post 7715064)
Thinking about going to a set of 6 bar muranos, glad I found this. I was wondering if i needed a 40 or 45 profile....
© 2024 MH Sub I, LLC dba Internet Brands
