G35s Rub after drop
Old Oct 3, 2010 | 02:02 PM
Remminator's Avatar
G35s Rub after drop
Did I do something wrong? I installed previously paired agx/intrax springs with slightly more than 2" drop now my tires rub when I hit dips in road. Has anyone else experienced this? 235 40 18s
Old Oct 3, 2010 | 03:19 PM
Did you get the car aligned?
Old Oct 3, 2010 | 04:47 PM
Remminator's Avatar
Yes, dude who did allignment told me that I shouldn't have dropped it without putting "spindles" on it, whatever the f*ck they are. From what i've read on the org, this is one of the most common and popular mods on 4 gen maximas, and G35 rims are a very popular rim. Just don't understand how my set up rubs and others don't. Already posted in tires/wheels thread with not much help there.
Old Oct 3, 2010 | 04:57 PM
MAXC's Avatar
Whats rubbing, front or back? are you using spacers? and do you have any pics of the proposed problem? And the dude who did the alignment is really blowing smoke up your a**
Old Oct 3, 2010 | 05:25 PM
phatboislim's Avatar
yea i dont see why you're rubbing...are you rubbing rear or front..also pics. a rolled fender should fix your problem...BUT i dont see why you're rubbing *scratches head*
Old Oct 3, 2010 | 05:45 PM
Remminator's Avatar
Front is rubbing, No spacers.
Old Oct 3, 2010 | 06:06 PM
Bonka's Avatar
Schnell kaputt
What's your front camber at? Most alignment shops with lowered cars will add some negative camber in the front.
I would just roll the fenders.
Old Oct 3, 2010 | 06:19 PM
CustomLowz's Avatar
Stupid question, but are the wheels OEM staggered? If so, do you have the front wheels on the front and the rears on the rear?
Old Oct 3, 2010 | 06:31 PM
2000_MAXIMA_KING's Avatar
in pic looks like he has them reversed
Old Oct 3, 2010 | 07:13 PM
MAXC's Avatar
How are your struts? when you push down on the front end (make it bounce) it should bounce once then level off. If it keeps bouncing then your struts are gone. another thing. are your agx's adjustable? if they are then try stiffining them up a bit.
Old Oct 3, 2010 | 07:18 PM
maxxxdout's Avatar
I have this same issue with my car, but mine rubs in the back. But it will only usually happen if its a substantial dip in the road.
Old Oct 3, 2010 | 10:23 PM
Well, if he got OEM G35C rims, and not replicas, the offset is +30 for both front and rear.
The OP should pull the wheels and check the offsets, as the offsets are stamped into to back of one of the spokes. And check to see if they are indeed genuine (Nissan will be stamped into the back of the wheel as well).
Old Oct 3, 2010 | 11:06 PM
QT1 5MT AE's Avatar
Gram Lights addict
these are 18x8 +30 all around from the factory. those DO appear to stick out too much for that spec so as the wizard said, check to see if they are legit wheels or not. either way, 235's with +30 is bound to rub on an 8" wheel with 2" drop. Thats pretty much a fact so im not sure who told u they wouldnt. step it down to 225 with -1 degree camber
Old Oct 4, 2010 | 03:02 AM
Remminator's Avatar
I know someone on here who has these same tires/rims combo with 2" drop and doesn't rub. I'm guessing it has something to do with camber, and his is a 99, mine is a 95.
They are definately OEM, have the nissan stamp on all of them. How do I adjust the camber?
Old Oct 4, 2010 | 04:26 AM
i thought these were 18x8-front and 18x8.5-rear....do you know how to check your width on the back of the wheel? its stamped in one of the spokes...
as far as camber...i'd just take it back to the shop and tell them to add some camber, although i dont know how many degrees to tell them to add for you, i'm sure someone will give good advice...but i'm thinking something minor like .5(degrees) because it doesnt look like its rubbing too extreme..or like i mentioned..rolling the fenders always works
Old Oct 4, 2010 | 05:25 AM
Remminator's Avatar
To be honest, I never looked at the back until this morning and noticed they actually have front and rear stamped on there, do all oem g35s have wider rear?
Old Oct 4, 2010 | 05:27 AM
G35 and 350z run staggered oem wheels...usually 8s up front a 8.5s in the rear...do you have all rears or all fronts? btw i think the rear offsets are like +33 if i remember correctly, dont quote me
Old Oct 4, 2010 | 05:50 AM
Remminator's Avatar
I have two front and two rear, I may have had fronts on rear and vice versa
Old Oct 4, 2010 | 06:34 AM
yea check the rears...it shouldnt be rubbing
Old Oct 4, 2010 | 08:28 AM
You thought wrong. 18x8's all around.
Yes, but only for slightly wider TIRES.
Incorrect. Not all run staggered wheels.
18x8 G35C rims are +30 all around.
Again, look for the offset stamped in the back of the spoke and confirm they're +30.
All you can do is add some camber or raise your car slightly. Your choice.
Old Oct 4, 2010 | 08:35 AM
according to you putting me on blast and what i found after you put me on blast, theres no need for him to check anything else...you were correct, about the width 18x8, and the offsets are all the same as well +30
http://forums.nicoclub.com/g35-g37-o...s-t342067.html
which brings us back to square one...
your fronts are whats rubbing right? only thing i can recommend is run a little camber but since i'm sure you want to try to preserve teh life of your tire...i just say roll the fenders. get someone that will do it correct so that it wont crack your paint at the seam. what i mean by 'the correct way' is that they use a heat gun of some sort so that it will soften the paint so that it will 'flex' with the metal
Old Oct 4, 2010 | 08:43 AM
Remminator's Avatar
I think I'm gonna raise it .5 - 1 inch
Old Oct 4, 2010 | 08:49 AM
Crusher103's Avatar
unless u run an OEM stretch ur gonna rub. I use to have some Z wheels the fronts would rub when i put 245s on them when i was running 225s no rub. Its not gonna do any damage it just sounds annoying.
The front u need not worry about The REAR, there is a sharp lip in the rear fender that will slice through tires. Have the rears rolled.
Old Oct 4, 2010 | 09:04 AM
It still couldn't hurt to check the offset as many guys run G35C rims with no rubbing issues, and with substantial drops.
LOL at putting you "on blast". It was already established that they're 18x8's with +30 offset yet you still kept mentioning other possibilities; hence why I quoted and corrected you....or put you "on blast" as you call it.
You do realize there is a G35 wheel sticky in the wheel forum, don't you? No need for nicoclub link.....
Old Oct 4, 2010 | 09:06 AM
i ran a google search and that was the first link, i didnt know of our wheel spec page/sticky
Old Oct 4, 2010 | 09:44 AM
QT1 5MT AE's Avatar
Gram Lights addict
nope, cant be. 235 on an 8" wheel with +30 will rub on this sort of drop.
Old Oct 4, 2010 | 11:26 PM
Snypa's Avatar
^^ I dont rub,and i have similar drop and same tire sizes...fren doesnt rub either and he has coilovers. I thought all coupe 18x8 wheels came with +30 offset, how is it no one else had this problem. Even the replicas are +30 offset but instead are 18x7.5, so my question now is...does Remminator have wheels that no one else has?
P.S even if the OP puts front to front and rear to rear, he will be back to square one when he rotate tires unless he unmounts etc. Would be good if you could measure all 4 rims to see if they are all 18x8. Only rear fenders can be rolled.
http://forums.maxima.org/tires-wheel...s-maximas.html
Old Oct 5, 2010 | 12:00 AM
QT1 5MT AE's Avatar
Gram Lights addict
^ with enough compression, you will.......different tires have different contact area and strech but 235's is still bound to rub.
Old Oct 5, 2010 | 12:13 AM
Snypa's Avatar
^ Ok, but no one else's G35c's stick out that much, if he had on my wheels, no way he would rub, my entire wheel sits inside the fender. From the Op's pictures, it would seem as though its the edge of the tire that's rubbing and not on the top where the tread is (I can be wrong).
Old Oct 5, 2010 | 05:29 AM
Remminator's Avatar
Def oem g35, 30mm offset. Maybe something wrong with other area such as knuckle, control arm etc? Did check this out and looks good from my pov, but I'm a novice when I comes to suspension etc
Old Oct 5, 2010 | 05:31 AM
your car must have been in an accident or something just to knock it over that much. because its just that one driver side thats rubbing right? as was mentioned i've never seen the Gs stick out as much as they have in your car
Old Oct 5, 2010 | 07:18 AM
Remminator's Avatar
Not that I'm aware of, no evidence of overspray or bodywork. I wonder if there is a suspension component that needs to be adjusted/replaced?
Old Oct 5, 2010 | 07:20 AM
Crusher103's Avatar
ur wheels are bootleg then......
Old Oct 5, 2010 | 07:21 AM
Crusher103's Avatar
i have an I30 which has alittle bit larger fenders and i will rub and the wheels will poke out the fender alittle, the only way i didnt rub is when i ran 225s.
Old Oct 5, 2010 | 07:38 AM
yea fronts are generally flush, but rears sit in...
as far as the OP...i'm out of reasons why you're having the issues you are having
Old Oct 5, 2010 | 08:43 AM
Snypa's Avatar
I'm just trying to say that they dont come nowhere near the OP's.
P.S OP try and measure the rims yourself if you can and determine the width and let us know how the "F" to front and "R" to rear situation works.
Old Oct 5, 2010 | 08:49 AM
Snypa's Avatar
I cant remember if my wheels has front or rear stamped in them. Just for that fact alone, I would think they are different specs.
Old Oct 5, 2010 | 11:02 AM
Crusher103's Avatar
ur running a stretch b1tch thats why u dont rub. beef those tires up and u'll start rubbing like the rest of us.
Old Oct 5, 2010 | 11:15 AM
Snypa's Avatar
^^Did you stretch em !? I run 235/40/18 Falken ziex ze-512's in that picure and still have them on at the moment. No rub at all. But we're straying from the point here, the OP still has problems.
Old Oct 5, 2010 | 11:34 AM
NmexMAX's Avatar
dot dot dot ...
Depends on the tire too.
I had 1 brand of tires and never rubbed, changed tire brands, kept the same size, and rubbed like you wouldn't believe.
