G37S 19" Rims on 5th Gen - Spacer/Drop questions.
Old Dec 26, 2010 | 08:17 PM
TunerMaxima3000's Avatar
Bought a set of 19" 10 spokes from 2008 G37S, I know a few of you are running them.
Tire sizes are stock - 225/45 front 245/40 rear
Question is - What spacer size in the rear to bring them flush like the fronts? I was acutally surprized the front stick out a shade, thought they were +45 offsets???
From tape measure looks around 10mm/15mm spacer, anyone running these know what is best??
Also, I obviously need a drop desperately. How low are you guys running without rubbing and what set up? Front definately needs more of a drop than the rear.
Old Dec 26, 2010 | 08:51 PM
s1mply_v's Avatar
Look at this link..
http://forums.maxima.org/tires-wheel...oupe-rims.html
I didnt need any spacers at the time. The wheels sat pretty close flush both front and rear. If your realy ****, the most you'd need on the rears are 5mm, but its not worth the cost of spacers seeing that its so thin. You probably wont notice the difference anyways at 5mm.
Old Dec 26, 2010 | 10:13 PM
Originally Posted by s1mply_v
Look at this link..
Thanks for the reply. I noticed it by measure its about 20mm difference from front to rear (front sticks out 10mm rear in 10mm) but I'm probably just being a bit picky. Will price spacer to see.
Anyone bother to run a spacer?
What kind of drop did you have set up with them?
PS. I gotta know man, I have searched and searched, where can I get that grille?? Or did you swap to 5.5 front end?
Old Dec 28, 2010 | 11:19 AM
s1mply_v's Avatar
I was dropped with D2 coilovers back when i had the G37 wheels.
Are you referring to the grille in my sig or the grille in the photo with the G37 wheels?
Old Jan 4, 2011 | 12:27 PM
A-City193's Avatar
You can buy this grill on ebay copy paste this on ebay :
JDM Nissan Maxima 02-03 Front Bumper Mesh Grill Grille
its 89.99
MAXSE5SPD
Sep 17, 2022 04:00 AM
adamgalazka
Sep 8, 2015 01:27 PM
boomerbrian
Sep 4, 2015 08:25 AM
Lowered_a33
Sep 1, 2015 07:49 PM
