tsw rims from a mustang
Old May 15, 2011 | 02:26 PM
sergey85's Avatar
i was wondering if the rims from a mustang will fit my 02 maxima its a newer mustang. the bolt pattern is 5x114.3. just weant to maker sure cause these wheels are nice. thanks
Old May 16, 2011 | 04:51 PM
OC_Nooby's Avatar
If the Moo-tang has 5x114.3 then yes it will work with your Maxima
Old May 17, 2011 | 02:26 PM
asand1's Avatar
Yes they will bolt on. The offset and width will determine whether they fit.
Old May 29, 2011 | 01:54 PM
itgogitrev's Avatar
Double check offset and the centerbore diameter. You might need new centerbore rings... not sure what a Mustang's CB is.
Old May 30, 2011 | 11:39 AM
asand1's Avatar
Mustang CB is larger than max. They will fit, rings are a good idea, but you'll get by without them. Remember to re-torque a couple times. Offset and width might be a dealbreaker though.
Old May 30, 2011 | 01:59 PM
asand1's Avatar
Mustang =70.3mm
Maxima =66.1mm
I don't see ready made rings this size anywhere.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
REDinLV
Sep 28, 2015 12:31 AM
Pixel
Sep 15, 2015 05:53 AM
0m3nc0w
Sep 11, 2015 05:21 PM
