Tread Measurement... Penny vs. Actual Gauge
Old Aug 1, 2011 | 11:17 AM
Mikeb120's Avatar
Hi,
I normally just use a penny to measure but when I used a penny to measure two michelins they were covering a small portion of lincolns head for around (2-3/32) but the tread gauge read 6/32.
The tire guy said michelins can't be measured with the penny cause of the grooves..
Anybody heard of this?
Thanks,
Mike
Old Aug 5, 2011 | 08:37 AM
asand1's Avatar
Did you measure in the same exact spot? I ask because if you look in the grooves you'll see wear bars(raised portions) that indicate 2/32 when flush with tread surface. If you measure there you will get a false measurement (-2/32).
Old Aug 5, 2011 | 08:40 AM
asand1's Avatar
Thanks,
Mike
BS 2/32 is 2/32. And a grooves a groove.
my03maxima
Jul 28, 2024 07:40 AM
Miket2006
Mar 1, 2021 03:55 AM
mkaresh
Mar 12, 2018 06:48 PM
